Vista 15P Wiring
  • Thread starter SanguineIllusion
  • Start date
SanguineIllusion
Anyone happen to have a Vista 15P wiring diagram on hand? I'm doing
some research to try to install it myself or at least understand
better how it works if I decide to go with a professional installer.
F
Frank Olson
There's usually one inside the door of the can, however, that is NOT
going to help you much. What you need is the installation and
programming manual. And if you don't have the full alpha keypad, you're
"hooped".
Robert L Bass
Call and I'll give you access to download all the manuals for free.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
F
Frank Olson
Mark said:
Another RLB wannabe DIY'er
I hope he's not expecting actual "help" from an idiot that thinks
there's a 24 volt version of the Vista 128.
Robert L Bass
Mark said:
Or the idiot who thinks the Allegro has an integrated dialer
He's wrong about the Vista-128. It is indeed available in a 24 Volt model.
Here's a link to a page describing the unit:
http://www.bassburglaralarms.com/product_319216_detailed.htm
There are 52 of them in stock.
There are several kits available which include the 24-Volt panel which
actually cost less than the panel only. For example, the
V128FBP-PAK2 consists of a 24-Volt Vista-128FBP, a 6160CR commercial fire
keypad and a 5140DLM dialer module. This kit retails for $624. Here's a link
to the kit:
http://www.bassburglaralarms.com/product_319217_detailed.htm
Regards,
Robert L Bass
Fax 941-870-3252
Doug
F
Frank Olson
model. Here's a link to a page describing the unit:
<snip>
fire keypad and a 5140DLM dialer module. This kit retails for $624.
Here's a link to the kit:
<snip>
And if you want proof that burglars avoid "Alarm Farce protected homes",
please feel free to visit *their* website.
You're so full of yourself, it's amazing. Why not RTFM, Bass
(specifically page 3-4)? The Vista 128 is a 12 volt panel. The 128-24
incorporates a 24 volt power supply module (called a PS-24) that
converts the NAC circuits to 24 volt DC outputs. There is no "24 volt
version" of the panel. You can purchase the module separately and
install it on *any* 128FB to accomplish the exact same thing. You're an
idiot, Bass. You've obviously never seen one, sold one, installed one,
or provided technical support on one and *this* proves it.
Page 3-29 details the connection requirements of the PS-24. Page 3-30
tells you SPECIFICALLY how to hook up the batteries. GASP!! There's a
12 volt battery to power the 128FB and a 24 volt battery to power the
notification appliances... Gee... That must mean that the Vista 128 is
a 12 volt panel...
While we've got the manual open, why not go to page 3-8 where it lists
the compatible two wire smoke detectors approved by UL. Do you see the
Napco Firewolf two wire smoke detector there anywhere? So much for your
"expertise" in fire alarm.
F
Frank Olson
Doug said:
Not to worry Frank, it could be worse, at least you didn't keep harping on
about an idiot who thinks there is a 24 volt version.
I saw that exact same webpage a couple of years ago and thought much
like Bass did. It wasn't until I read the manual and understood that
the *panel* is not 24VDC. Only the module powering the NAC circuits is.
F
Frank Olson
Mark said:
No I WAS talking about the same idiot, I was just asking if I said your
name
ROFL! You're good. Ever thought of doing stand-up? You'd have tons of
young women throwing their bicycle shorts at you on stage... :)
Jim
ROFL! �You're good. �Ever thought of doing stand-up? �You'd have tons of
young women throwing their bicycle shorts at you on stage... �:)-
Dirty, sweaty, smelly, skidmarked ...... bicycle shorts.
