Volatile and interrupts
electronicsLearner77
Jul 2, 2015
306
Is it mandatory that a variable that i use in interrupt to copy microcontroller buffer data should be of type volatile? Because without it also my code seems to be working.
Look up Arduino volatile in Google, there is a good explanation there.
It really depends on whether or not you want to chase down weird bugs.
Be aware though that the volatile keyword disables some optimization, so you may need to carefully consider where and when you want to get the current value.
For example if the variable conntrols the color of 100 LEDs and you set them all in a loop, you may wish to consider if you want to set the LEDs to the color as it was when the loop started, or never each LED set to the instantaneously determined color.
