http://cyntech.co.uk/downloads/neoway-m590-hardware-design-manual-v1.pdf
The m590 says it's not 5v tolerant 3.9v max or there abouts... but if i run an Arduino and tjis m590 module from a single 18650 it will see around 3.8 - 4.0v
It came in kit form so i'm going to solder or heat gun it then use a usb to ttl converter or WAS (5v usb!)
How about simply tying the grounds but letting the lithium battery power it all?
Bottom line. .. a voltage converter needed ? Thanks
