Voltage Divider Resistor Picker
Tim
There are 480,000 different combinations of standard 1% resistor values. If
you need 2.75 volts from a 5.00 volt reference, which of those 480,000 pairs
will give you the closest result?
For this example there are 9 resistor pairs that will get you to within
0.5%, but one resistor pair will get you within 0.15%. Only 1 out of 480,000
combinations is the best pair!!
The Best Pair II resistor calculator program will calculate and display the
twenty one best voltage divider resistor pairs, as well as the error
voltages, percent error, "Perfect R2" and "R Thevenin" values. Results can
be scaled to any decade of course.
BestPair has been upgraded to Best Pair II. If you are interested you can
get it with instant download delivery here -->
http://www.velotec.com/BestPair.htm
Thanks for looking.
Cheers,
Tim
www.velotec.com
N
nospam
Rich Grise
Updated :-
"It now supports E192 range and supports selection from mixed ranges.
It no longer rounds input values to 3 significant digits. It can run
multiple instances (which is more a bug than a feature)."
at http://web.newsguy.com/pentangle/ResCAD20.zip
The number of times that I've had to select values from a range like
that, I've done it "by hand" with a spreadsheet. ;-)
Although, it would be kind of a fun programming project - maybe I'll put
up a "divider calculator" web page. ;-)
Cheers!
Rich
redbelly
Tim said:
If they are 1% resistors, then NO pair will be within 0.15% !!!
Mark
Spehro Pefhany
Mark
Typically 1% resistors are within 0.15% or so.
Nothing wrong with trying to get closer to the ideal values on analog
stuff.
Best regards,
Spehro Pefhany
The Phantom
This isn't unqualifiedly true. Some pairs MAY be within 0.15%; some may not.
What you want to say is that there is no guarantee that any particular pair will
be within 0.15% when built with real 1% resistors.
