[email protected]
- Jan 1, 1970
- 0
Hi, recently I`ve started to work (ad honorem, as a Technician) on a
Mechanical Engeneering Lab that performs destructive tests. They have
tasked me (I`m in the Electronic Instrumentation Department) to design
an electronic circuit that will replace an obsolete Voltage Gain Switch
circuit. The obsolete circuit uses relays to change the operational
amplifiers with different gains. Basically we are 2 guys, I`m an
Electronic Technician on the first year of electronic Engeneering and
who's in charge is an about to graduate Electronic Engeneer.
The requirements are:
+-10V output voltage swing
Low Frequency, from 0 to 200hz
Low Cost
Easy-to-find ICs (ICs with high Availability)
4 selectable gains controlled by two bits
Null-Offset
High Precision Gain
The Technician before me did this circuit with 4 Operational Amplifiers
with different gains and an analog switch CD4051 or CD4066. This
circuit did not meet the requirement of +-10V output voltage swing, so
I have to redesign it. The gains are predetermined, I don`t have the
actual values right here, but the maximum was 5000. My idea is to
change the analog switch with one that does allow at least +-10V output
voltage swing, and my "boss" approved. The thing is that I tried to
find a replacement but couldn`t find one that`s available here in
Argentina.
To sum up what I`m asking for is a suitable IC, or a new idea on how to
make the circuit. Of course ideas to improve the original design are
always welcome. I know about amplifier design, but on the Technician
level, that is, I don`t know any practical or modern way of doing it,
just what the theory says. As you can see the requirements are
standard, not very demanding (I guess), if there's anything you think I
should consider please tell me about it.
Thanks in advance.
Low Cost
Null-Offset
High Precision Gain
Argentina.
Thanks in advance.
