Voltage Level shifting
mdaien
Mar 4, 2007
9
Hello friends,
Initially I have to convert the 24V signal to 5V which I did using voltage divider circuit but now the thing is my input signal level is not decided it may vary from 15V to 24V so the question is how can I maintain 5V.
My input is varying from 15V to 24V but I required 5V output.. how can I do this??????????/
;D
jgeidl
Feb 24, 2006
35
Try Googling 7805 voltage regulator.  This device with a few caps will control the output.  There are about a million circuits out there using it as it is very common.
Jim
mvs sarma
Feb 12, 2006
234
mdaien said:
Hello friends,
;D
you didn't mention how much current you want to draw at 5V --neither you mentioned whether it is DC or AC-- i
if Dc you want large currents  use 7805 with adequate Hestsink.
if dc and for very small currents like less than 5 mA use a high watt (2watts)resistor of say220 ohms and a 2 watt zenor diode of 5 V or 5.1V (generally available
if it is AC power  you have to adopt different techniques.
Sarma
