Voltage Level Switch
Supercap2F
Mar 22, 2014
550
Dan Paulovich said:
What would I use for the U1 voltage regulator.
U1 is just the power connections for the comparator. :)
I'm going to power the circuit from a garden tractor, probably 13-15 vdc when running.
I thought you wanted to power it off of 12VDC.:confused: You will need a voltage regulator if you want to power it off of 13-15VDC.
Regards
Dan
This is what I meant:
Sorry, R1 and R2 are labelled backwards as compared to your circuit.
Note that depending on the comparator (and especially if you're using an op-amp as a comparator), the input voltage range may not extend to the negative rail. In the case of the one shown above (the TLC3702) it does.
And, once again, is the 12V regulated? If not you need a voltage reference.
Gryd3
Jun 25, 2014
4,098
Having a regulated 12V source would allow this to be more stable... and would prevent the alarm from triggering on a false positive from the 12V source drifting. This of course will depend on what kind of accuracy the OP wants.
Alternatively, does anyone have any objections to using a diode on the + side of that Comparator?
+12V----\/\/\/\----+---->|----GND
You would need to feed the output from the Aneamoter to a voltage divider, but that would ensure a more stable reference voltage would it not?
