To the OP. What is the peak-to-peak signal voltage at the sound card's input that causes the sound card to clip?
Q1 and Q2, no. The others, yes, but with circuit changes. I suggest you get some transistors! They can be pretty useful. You may be able to find a bulk pack with a selection of NPN and PNP small-signal transistors.Wow! all that transistors for a led? Can i replace the transistors (don't have a lot of those) in your circuit with mosfets (i have a lot of those)?
I hadn't noticed that you intend to measure 400VAC. That's potentially very dangerous and I strongly recommend against it. At the very least you will have to ensure that your input resistors and input selector switch are rated for this voltage. Your best option is to use an external x10 or x100 probe, as suggested earlier by duke37.
Good. The x100 probe is probably designed to work with a measuring device that has a specific input impedance. Check the manual for the probe.I have an x100 probe and i will also use pots for the attenuator instead of fixed resistors and a switch.
Where did you get that idea? They should be normal bipolar transistors. They only need to be rated for 100 mA and 30V. They should have fairly high gain. I suggested some suitable part numbers for them in an earlier post, and on the diagram.So the transistors should be logic gate right? and can use small ones like 300mA?
You're welcomeThank you very much.
