Voltage rating of Capacitors.
HellasTechn
Apr 14, 2013
1,579
Good day to all !
Like most of us, i have come across various types of capacitors with many different voltage ratings.
strange thing is that on computer motherboards most capacitors are rated 6.3 Volts and that value i have only seen on computer motherboards. Isn't that strange ? anyone knows why ?
Anon_LG
Jun 24, 2014
453
They may be required to keep a ±25% tolerance. 6.3V-5V = 1.3V. 1.3/5 = 0.26. Close enough to 25%.
HellasTechn
Apr 14, 2013
1,579
why do you think it is strange ?
they will be on either 3.3V or 5V rails
Well mostly because i havent seen theese in other circuits.
most commonly Circuits runing at 5volts use 10volts capacitors. circuits runing on 12 volts use 16 volt capacitors.
14,481
without knowing the specifics, the 6.3V ones may all be on the 3.3V rails
gorgon
Jun 6, 2011
603
There is also a size problem for big capacitors vs higher voltages. Finally also a price problem, lower voltages are cheaper to make.
AnalogKid
Jun 10, 2015
3,051
A general rule of thumb for capacitor reliability is to use a voltage rating that is at least twice the peak voltage the part is likely to see. In this case, a 6.3V cap is close for a 3.3V application. Not exactly following the rule, but motherboards are notorious for squeezing every micro- penny out of the BOM. The world consumes about 20 million motherboards a year. Every penny equates to $200,000.00.
ak
cjdelphi
Oct 26, 2011
1,166
I've been using a 16v 10000uf cap on a solar panel which supplies 19v/10w solar panel...
Not yet exploded (handles 19v ok lol) ...
Yet :p
14,481
Yet :p
well that is a little silly ... seriously
but on the other hand, it's probably not a 19V panel, that's probably its open circuit voltage
it's loaded voltage is more likely to be ~ 12 - 16V
cjdelphi
Oct 26, 2011
1,166
I measured 19v with full light...
And i'm happy to take the risk because when the panel is in use, the cap never reaches 19v under load..
Having said that, could i get away with 19v on a 16v cap... i bet i could, i just doubt it would make it's life expectancy...
Electrolytic caps really only explode if you pass more than a few volts higher than rated (3v higher (16>19v) could try this myself supply around 30v) or you reverse polarity on them...
Anon_LG
Jun 24, 2014
453
Yet :p
Have you seen electrolytic caps explode?! Search YouTube for "Russians explode caps in house", in the one I watched, they tested on their furniture and there was dust everywhere. The stuff pops out of the top and becomes airborne, I am guessing not so good for your lungs!
It is not a matter of exploding, it is a matter of degrading. Electrolytic capacitors essentially have material plated on a substrate. A voltage higher than the rating reverses this process and the material is removed, eventually causing failure.
chopnhack
Apr 28, 2014
1,576
I had one explode inside of my enclosure for my 'wired' wireless rain sensor project. Due to rms voltage rating not being taken into consideration! oops, rate your caps appropriately :)
