Voltage Reducer
log
My frequency counter is IC based with one of its
pin as direct input.. about 6Volts. Now I want to
measure the frequency of the power lines. I plan
to use a step down transformer of 110 volts to
6 volts secondary. Can I use the connect transformer
6 volts output directly to the pin of the IC.. or do
I have to use some kind of current limiter. If so. What
current limiter must I use? Or does the IC only draw
the required few current it needs without the transformer
overloading it? Thanks.
log
V
Vlad
log
Give us more details on the input IC you are using.
In any case a resistive network should be in order, provided you don't
need ground isolation. If you do, the transformer makes more sense.
Vlad
