[email protected]
- Jan 1, 1970
- 0
We're designing a DC power supply through the use of a transformer, a
rectifier and a capacitor. We've finished that, and would now like to
regulate the voltage to *almost* pure DC through the use of a zener
diode in parallel with the capacitor.
The problem is that in PSPICE, the software we're using to model the
circuit, the voltage waveforms we're getting from using a zener diode
don't look like they "should." I say they don't look like they
"should," because from what we've learned, the response doesn't make
sense.
As far as I've learned, a zener will break down when it's in reverse
bias at some specified voltage (the one in pspice was determined to be
about 4.6 volts through the use of a simple DC power supply in series
with a zener and a load resistance). Since the breakdown is so
dramatic, the current can increase a lot more with very little change
in voltage.
So, just for an example, this circuit:
http://pg.photos.yahoo.com/ph/benfortener/detail?.dir=1835&.dnm=16bd.jpg&.src=ph
should just limit the voltage at 4.6 volts (as long as the current
flowing through the zener is within specified power regulations), and
once the input voltage goes to more than 4.6 volts, it shouldn't
matter, and the voltage across the diode should still be about 4.6
volts.
It produces this output:
http://pg.photos.yahoo.com/ph/benfortener/detail?.dir=1835&.dnm=1651.jpg&.src=ph
The red is what I thought it should do and the black is what it does.
Any information anyone could offer to me on zener diodes or why this
isn't working would be greatly appreciated.
Ben
sense.
in voltage.
volts.
Ben
