Hello Forum!
I am stuck due to a simple problem that arose in my project. I want to trim the voltage that a source produces without any significant loss in the current. I have attached a couple of pictures that roughly characterizes the source I am talking about. I want the output voltage to be regulated at around 2 Volts (2V plus or minus 0.1V) for at least the first few seconds until the source voltage drops below 2 volts or till the source voltage reaches zero. I also want a significant amount of the source current at the output side as I will use that to charge a supercapacitor. In any case, the output voltage must NOT go beyond 2.4 volts as it will damage my supercapacitor. I am looking for a circuit(s) that come in-between the source and the supercapacitor that fulfills the above requirement. Suggestions please....
