Voltage Regulator Help
Bruce Johnston
Jan 27, 2018
Hello all.
This is my first post at this site. Forgive me if I do something wrong here!!
Here is my question. How can regulate 12.6vdc to 14.5vdc (the typical voltage measured on a car battery when the engine is running to the point when the engine is turned off) down to a fixed 12vdc? Most, if not all, regulators require about +3vdc above the target voltage to regulate peoperly. My goal is to obtain a regulated 12vdc @10 amps.
Thanks in advance.
14,487
Hello all.
Thanks in advance.
hi and welcome
use a DC-DC buck converter ... dirt cheap on eBay .... 10 A ones are not quite as common, but are available
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
@Bruce Johnston welcome to Electronics Point!
To expand just a little on Dave's reply... you first need to convert the variable battery voltage (12.6 to 14.5 V DC) to a higher DC voltage that can then be regulated down to your desired 12 V DC. A switch-mode power supply (SMPS) is typically the method used to do this. The SMPS uses the raw DC voltage from the battery to drive a power oscillator that stores electrical energy in between cycles of the magnetic field of an inductor. The cycles are not necessarily sinusoidal, but that is beyond the scope of this comment.
The cyclic electrical energy stored in the magnetic field of the inductor is retrieved every cycle, rectified, filtered, and regulated down to the desired 12 V DC. This latter operation leads to the term "buck converter" meaning part of the input voltage is "bucked" to a lower output voltage. However, the voltage obtained from the magnetic field stored in an inductor very much depends on how rapidly the magnetic field is collapsed (circuit design) to retrieve electrical energy. It is therefore possible (and practical) to obtain more output voltage than the input voltage by using a "boost converter" SMPS.
SMPS technology didn't exist in a practical form until the development of low-loss, high-frequency, switching transistors, which today are typically MOSFETs switching at high kilohertz to low megahertz speeds, limited more by inductor core loss characteristics than MOSFET switching performance. The market boomed in the waning years of the previous century and is now flooded with very affordable, inexpensive, Asian products. Or, since this IS a forum for DIY hobbyists, you can "roll yer own" and learn about this fascinating technology at the same time. All the essential components are readily available online, as are "monkey see, monkey do" instructions. Make Google your best friend to explore the possibilities, but most of all have fun!
AnalogKid
Jun 10, 2015
3,058
If you are sure that the output voltge *always* will be less than the input voltage, there is a variation of a linear voltage regulator called an LDO - Low Drop Out. While these usually are used in applications of lower current, there is nothing preventing an LDO with a 10 A output and 0.5 V in-out differential.
Other than money, size, and money.
ak
