In the data sheet for a chip (qt301 from qprox.com) I am using it says the following:
"If the power supply is shared with another electronic system, make sure the supply is free of spikes, sags, and surges. The supply is best locally regulated using a conventional 78L05 type regulator, or almost any 3-terminal LDO device from 3V to 5V".
Ok... I can't use 78L05 because the supply is at 5V. So I will need to use a regulator that gives 3.3V or 4V ouput. As always in electronics, there are HUNDREDS of different parts to choose from, and many don't have basic circuits that show you how to make a basic "fixed" voltage regulator (i think it's called fixed). Also, there a very few regulators that are called "fixed", so I'm guessing the "fixed" regulators have the capacitors in the IC already???
I believe if they are not designated as "fixed" I need to use two capacitors...
If anyone can point to a part and a circuit that would be very nice...
B.
B.
