Voltage to current converter circuit
Arouse1973
Adam
Dec 18, 2013
5,178
The op-amp used was modified to have a low output resistance. As I told you a buffer might be needed if you can't find an op-amp with enough current handling capacity.
Adam
Bharanidharan
Jul 22, 2014
25
Adam
Does this buffer needs to be at the output of the differential amplifier?
Arouse1973
Adam
Dec 18, 2013
5,178
The buffer needs to be what is driving the load. Think of inserting it inside the op-amp and the output of the buffer now being the output of the op-amp.
Adam
For the third time, why not use an off the shelf audio power amplifier??????
Bharanidharan
Jul 22, 2014
25
Bob,
The LME49722 is an audioop- amplifier, which i used. I did mention that in the previous reply.
Results were similar. it was the one which had much current output. So i picked it.
Will update if I come up with anything.
Bharani
If you did, you did not tell us about it here. You mentioned trying two different opamps, one that could deliver a max of 50mA and the other that could deliver a max of 200mA, and then you complain that you cannot get 1A.
Find a Audio Power Amp (which is NOT the same thing as an opamp) that can deliver at least 20W into an 8 Ohm load and it will work.
Here is an example:
http://www.digikey.com/product-detail/en/LM1875T/NOPB/LM1875T/NOPB-ND/1669
Bob,
Bharani
Do you even bother to read data sheets?
IOUT Output Current V= ±15V ±23 mA
That is an OPAMP that can only put out 23mA.
