Volts Amps Watts Help I'm Dumb
BOnepaIn
If I buy a generator that produces 1000 watts @120 volts which makes
8.3 amps, but use the 12 volt outlet plug how many watts and amps
does it make? I'm talking about this generator
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_
200313480_200313480
It has 120v and 12 v outputs and states it makes 1000 watts at 120
volts; how many watts and/or amps at 12 volts (for charging a deep
cycle marine battery)?
John Popelish
200313480_200313480
There is not way to tell.
This manufacturer's data sheet doesn't mention the 12 volt
output at all.
http://www.easterntools.com/images/ETQ1200.pdf
Eeyore
200313480_200313480
The 12V output is presumably DC ?
It's anyone's guess. What does the manual say ?
Graham
Jasen
200313480_200313480
It's most unlikely to be more than 83A
(for charging a deep cycle marine battery)?
12V won't be enough.
Bye.
Jasen
does it make? I'm talking about this generatorhttp://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_
200313480_200313480
I've a generator that looks identical but is (UK) rated at 750Watts.
The 12V out is marked at 8.3Amps.
Lord Garth
Odd the manufacturer didn't label the 12 volt output as AC or DC.
I'd hate to hook it to a battery that needs recharging without knowing
the answer.
Rich Grise
Odd the manufacturer didn't label the 12 volt output as AC or DC. I'd hate
to hook it to a battery that needs recharging without knowing the answer.
The chances are 99.999999999% in favor of it being DC - I've never even
_heard_ of an AC generator with AC on the auxiliary 12V connector.
If it wasn't suitable for battery charging as it is, they probably
wouldn't have said that so in the ad.
Hope This Helps!
Rich
John Popelish
the answer.
In the exploded view, they list DC receptacle, DC rectifier
and DC circuit breaker. I would like to see the current
rating on that circuit breaker. They must not be too proud
of the DC output, because they don't advertise either a
voltage or current spec for it. I'm betting it is a very
crude 12 volt output good for a few amperes (less than 10),
continuously.
Peter Bennett
continuously.
As a possible comparison, my Honda EU2000i, with the 120 VAC output
rated at 1600 VA, provides a DC output rated at 8 A max, for charging
12 volt batteries. (the actual voltage of the DC output is not
specified.) It is much more efficient to use a 120VAC battery charger
than to use the DC output to charge a battery.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Lord Garth
Rich Grise said:
answer.
I'd like to see what charger circuit they use for the 12 volt portion of the
generator.
Lord Garth
continuously.
Only the most crude of chargers, I'm sure.
Lord Garth
Exactly as I feel.
neon
Oct 21, 2006
1,325
watts is the product of amps x volts so 1000 w is the total product available you can change the volts or you can change the amps as you like but the total can only be 1000w that is the criteria more then that adios generator.
