Watts vs Amps@Volts Rating
Raven Luni
Oct 15, 2011
798
Greetings,
One of those noob questions that doesnt come up till you need to ask it, but I was looking for some decent wire to use with some ultracapacitors I got recently (3kF, 2.7V). I went for some standard 3 core stuff rated for 16A @ 240V. Does this mean that it can handle 3840 watts of power regardless of current and voltage and therefore 1422 Amps @ 2.7V ?
No, it means that 16A and 240V are the maximums. So also 16A at 2.7V.
The maximum current depends not only on heating of the wire, but also how much voltage you are prepared to drop across it, and that means the maximum current will depend on cable length too.
CocaCola
Apr 7, 2012
3,635
In addition to what Steve state the rating is just a dumbed down 'rule of thumb' rating... In the real world the rating is dependent upon LOTs of other variables, and should be calculated on a case by case basis... Also these ratings are not necessary a 'wire' rating but more so a combined wire/insulation rating with heavy emphasis on the insulation... One big variable is distance, over a short distance the resistance of the wire is nil compared to a long run, thus it can theoretically handle a lot more current at short distances before it heats up vs a long run...
Raven Luni
Oct 15, 2011
798
Thanks. I doubt I'll be doing anything requiring more than a few amps but just wanted to be sure. As for keeping them shorted while not in use, I guess I should use a resistor to limit it to no more than 16A?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Another thing. The wire has resistance, proportional to the length. Thicker wire has lower resistance. This resistance limits the current you will be able to draw from the ultracapacitor. Even just 10 milliohms of resistance in the wire will limit the maximum current to 270A. And if you short the wires together with a fully charged ultracapacitor, the wire will dissipate 729 watts, which means the insulation will melt immediately and the wire will glow red hot!
So although you're not in danger of getting an electric shock from 2.7V, the extremely low internal resistance and enormous current available from an ultracapacitor means they're still dangerous. Don't wear any conductive jewellery while you're working with them!
