Wahl 8685 shaver repair
Luteguy
Hi all,
For posterity, here's a problem we had with our Wahl 8685 ("Peanut") shaver
/ trimmer, and how I fixed it.
It's a few years old and we use it for all our haircutting. My son was
using it the other night and he said it started sparking, whereby he
unplugged it.
I had a look inside and found that the design is fairly simple - a small DC
motor, a bridge rectifier, and a resistor. The resistor appears to act as
both a fuse and a small voltage-drop for the rectifier.
I don't know why it decided to give up the ghost, but the resistor was
intact enough to read it as either a red-green-red (1.5K ohm) or a
brown-green-brown (150 ohm) - I hate off-color resistors!
I put in a 1/2-watt 1.5K ohm resistor and the motor worked fine, but it
didn't have enough strength to power the blade assembly. I thought it may
also have been because the motor was failing, but I gritted my teeth and put
in a 1/2-watt 150 ohm resistor, and the shaver is back in the land of the
living.
I thought that someone, somewhere might be able to use this info in case
their resistor also blows but has an illegible value for determining
replacement.
Jim Adney
One thing that you might want to keep in mind is that the cutter
blades on all clippers need lubrication. It's just possible that yours
need some and that the extra load from the extra friction caused this
resistor to burn up.
These clippers always come with a small tube of light oil, and you
need to use some of it occasionally.
