Wall Wart Replacement source NOT RS
I am looking to replace the following AC/DC wall wart:
Bothhand Enterprises Inc
Model M1-10S05
AC Input 120VAC
Output: 5 VDC 2.0 AMPS
I am not interested in paying Radio Shack $22.00 for the privilege of replacing
a $3.00 item. Or several other places for $15+ plus s/h.
If possible I would like to replace with same item, but will consider
equivalents. OEM is wholesale only, as are many of its dealers." Sure how many
1000 do you want? 1, SINGLE, ONE. Sorry, min. 1 shipful."
Any useful suggestions (minus Google & Froogle) on sources for replacements
welcomed.
Thank you in advance.
Mike S.
Model M1-10S05
AC Input 120VAC
Regulated or unregulated?
welcomed.
www.jameco.com
If it isn't on their website, ask for their printed catalog. There are 9
pages (small print) of wall wart and tabletop power supplies in the
current edition.
Peter Bennett
Model M1-10S05
AC Input 120VAC
welcomed.
Have you tried the usual suspects? Digkey, Mouser, or Newark.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Michael Black
Model M1-10S05
AC Input 120VAC
I think you're overly optimistic on the price.
Run of the mill, and cheap, tend to be low current. Once you get up to 1amp,
I'd say the price rises. And by 2amps, they are less common so the price goes
up even further.
Given that this is a 5vdc adaptor, it's also not likely to be run of the mill.
The voltage suggests it runs logic devices, and hence needs that 5v to be
regulated, which will add to the cost. The cheap adaptors don't regulate,
and so use less circuitry.
Michael
Blake
Model M1-10S05
AC Input 120VAC
Output: 5 VDC 2.0 AMPS .. . .
welcomed.
BC Micro has a 5V 2A wall wart for $3.99 with 1.6mm plug.
See it at http://www.bgmicro.com/pdf/page13.pdf .
I don't know about their minimum purchase or handling charge, but it might
be worth it for you to have a look.
Michael A. Covington
From the current rating (2.0 A), it sounds like a regulated switcher. This
is not a $3 item. This one should cost $20-$40 in single quantities.
I'm not sure he realized that this is not like the cheap wall warts (like 9
V unregulated 300 mA) that we so often see.
Model M1-10S05
AC Input 120VAC
replacing
5 volts at 2 amps, regulated, is not a $3 item. It sounds like a regulated
switcher that should cost $20-$40.
N
Norm Dresner
www.allelectronics.com 5V 4A $8.50
www.bgmicro.com 5V 3A $4.99
5V 2A $3.99
I didn't check www.mpja.com but they might have something also
Norm
Michael Black
5V 2A $3.99
Norm
Of course, you are pointing to two companies that I think of as
surplus outlets
I'm with Michael, 5v at 2Amps is not so common, and not so cheap, at
"regular" places like Radio Shack. The fact that one can apparently
can get them at surplus outlets does not mean $20 or whatever is
overpriced.
I've bought plenty of simple switching supplies at the local surplus
outlet for a couple of dollars each, but that doesn't mean I can expect
to get them everywhere for such a low price.
Michael
Clarence
surplus outlets
overpriced.
Michael
Well I think you miss the point. The reason you can get them so easily surplus
is that in quantities of about 500 they are $2.56 from at least six different
suppliers. But if you want only a few. The surplus house is the better deal
since the manufactured have a minimum billing or sell samples for $20 to $50.
The fair price if you want a custom, but common, the surplus is a deal!
N
Norm Dresner
surplus outlets
overpriced.
Of course not. But for the OP's one-off, it's probably the best deal he can
get. That who the post was addressed to.
Norm
JeffM
www.bgmicro.com 5V 3A $4.99 5V 2A $3.99
Norm Dresner
:The voltage suggests it runs logic devices,
:and hence needs that 5v to be regulated
: Michael Black
Before I hooked a cheap unit to anything critical,
I'd check its output open-circuit and full-load (2.5 ohm 10W resistor).
If it's outside the 4.75V - 5.25V spec for TTL, I'd reconsider.
Even if the cheapie won't do this job, you're not out much $,
and you can keep it for other stuff or re-sell it.
N
Norm Dresner
: Michael Black
I won't say that I've bought hundreds of wall warts from these supplies, but
it does run into several dozen with a variety of specifications and there's
been no bad ones (yet). I doubt that they check each unit and I assume that
each one has gone through whatever it's manufacturer deems an appropriate
quality control procedure, but I do look at every one with a scope to see if
the output looks reasonable and I do meter the voltage. I think I'd do this
if I bought them from Jameco or Digikey too. And many of these are "name"
brand units that were surplus, not just cheap knock-offs.
Norm
