want to use Headphones and main speaker
Rizwan77
Feb 5, 2023
25
I have Sony Home theater and want to use headphones without cutting main speakers , How to do that ?
Alec_t
Jul 7, 2015
3,821
Welcome to maker.pro.
What audio output sockets are available on the system?
Alec_t
Jul 7, 2015
3,821
If so, then it looks as though it would mean tapping into the Front R and L speaker connections and applying the signals via variable attenuators to the headphones. I haven't checked if there is any module already available online to do this.
Rizwan77
Feb 5, 2023
25
Its DAV-SR4W, have stereo head phones jack , its 5.1 out for speakers, I want both at a time
crutschow
May 7, 2021
991
The only way I can think of to keep both on is to remove the cover and see if you can modify the headphone jack.
Below is a typical connection for such a jack:
The two stereo signals go to pins 2 and 3.
When there is no headphone plugged in the signals go out pins 4 and 5 to the amp.
When the headphone is plugged in it mechanically forces the contact between pins 2-4 and 3-5 to open, while contact is made to the headphones.
So to allow the speakers to always be on, you would solder a wire between pins 2-4 and pins 3-5.
Rizwan77
Feb 5, 2023
25
I am looking that kind of solution , only question is , that bypass make any harm to main amp ?
Rizwan77
Feb 5, 2023
25
I attached the pics of headphones jack and its wires going to main board, can you guide me which one need to be shorted ?
Rizwan77
Feb 5, 2023
25
I am still not sure about 2 3 4 and 5 pins, how to check this ? Which part's pic you want to figure out the connection
Rizwan77
Feb 5, 2023
25
That pic is back side of jack on pcb, only jack placed on this small peice, I mentioned it with red line , with 2 channels connectors
crutschow
May 7, 2021
991
You will need to use an ohmmeter to determine which pins are connected together when there is no plug into the jack, and all the pin connection to the plug outputs when the plug is in the jack.
Rizwan77
Feb 5, 2023
25
As I check and come to my knowledge , mechanically it cut common not L or R , I try to illustrate in pic with colors
