[WANT] USB > Serial adapter (plugs into RS232 port)
Scott Ehrlich
I have a device with cable having a USB connector to plug into a computer.
I want to get a USB-to-Serial adapter so I can plug the device into a
computer's serial port (9 pin). This is backwards from modern times, when
companies are offering devices to convert a serial connector to USB to
plug into a computer's USB port. _I am looking to take a USB connector
and plug into a Serial port_.
Any leads would be most helpful. This would at least be used for a
laptop.
Thanks.
Scott
CWatters
I guess you don't have a spare PC card slot for one of these...
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=289615&is=REG
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=307806&is=REG
Many other makes/types available.
Mike S.
You are not going to find such an animal.
The devices you see are not simply plugs with wires; they contain
electronics that are driven by drivers on the host computer that provide a
"virtual" serial port that is mimicked by those electronics.
To do the reverse ... plug a USB device into a serial port ... is simply
not feasible as there is no established way to make electronics and device
driver support to create a virtual USB hub.
Jim Thompson
I'll agree with Mike.
If one was available, though, it would probably be from Lantronics.
_But_, AHBPO, even if you get one you are going to have one hell
of a time getting the device driver in the computer to work correctly
via the serial port.
Your best solution is to change to a different computer or device (printer,
whatever).
You can buy a two-port USB adapter card for $3.87 ;-)
...Jim Thompson
