Hi All,
I am building a wood-gas powered off grid generator set up.
I will want the little car engine I am using to be self governing.
The ignition is currently via contact points and coil but I may soon transitorise this with a kit I built years ago. That uses a Hall effect sensor and I could pickup that as a triggering signal.
My plan is to take this signal (which would be 50hz at 1500rpm or 33.33hz at 1000rpm) and use it to then drive a small servo to open and close the throttle a small amount. That might possibly be a radio controlled car servo.
My thought is that I might use a Frequency to voltage IC to create a voltage related to speed. I was then thinking I might use a 555 PWM circuit to control the servo using the voltage related to speed to control the pulse width.
Has anyone done this or a similar thing and does anyone have a circuit diagram or advice on the best components to use and how I might achieve this?
Rob
Rob
