Wanted: Supplier of solder dissolving solution
Charles L
Could someone tell me of a supplier in Australia of solder dissolving
solution to clean PCB's?
Thanks in advance,
Charles L
Mark Harriss
Thanks in advance,
Charles L
Flux?? try some metho
Phil Allison
"Charles L"
** Does this post earn Charles L the "Fuckwit of the Year Award " ??
............ Phil
Rheilly Phoull
Phil Allison said:
"Charles L"
........... Phil
Gets my vote.
John_H
It's called universal solvent, but you have to supply your own
container. :)
Trevor Wilson
Phil Allison said:
"Charles L"
**And my vote. Google his name and read more of his stupidity. It is really
quite breath taking.
mark jb
Any pool shop. Probably even Woolworths.
Get some strong hydrochloric acid, and put your PCB's in a glass container
overnight.
Should clean the solder off pretty effectively.
-mark
Charles L
container. :)
Well actually I tell a lie. The solution was actually to dissolve solder off
of some IC's. But
someone told me I can achieve much the same thing using flux and a solder
pot. I think I
might give that a go. Thanks for your help though.
Charles L
O
Octa Ex
overnight.
-mark
Do you reckon that hydrochloric acid would damage ICs?.
If you could keep the air out it might prevent copper corroding, but
what about the tinning on the IC legs?
X X
X
X X
mark jb
X X
X
X X
I would assume the acid would eat the legs of the thing off.
Haven't got any acid around to try it out though.
-mark
F
Franc Zabkar
I prefer isopropyl alcohol. Methylated spirits tends to leave a white
stain on some PCBs.
-- Franc Zabkar
Please remove one 'i' from my address when replying by email.
John G
Thanks in advance,
Charles L
This must be a trol.
Anytrhing that will dissolve solder (usually lead and tin) will dissolve
any other metal in the vicinity.
Then the PCB will be a dead as a DoDo.
Trevor Wilson
**Nope. Old Charlie boy is THAT stupid. Trust me on this. I've had
discussions with him before. He's (quite) a few sandwiches short of a
picnic.
Charles L
There is in fact a product that is only available in the US as far as I can
determine
that will dissolve solder and won't affect the copper on the PCB. I am
trying to
find out if something similar is available in Australia and I haven't been
able to find
to date hence my original post.
Unfortunately I doubt whether I find will be able to find such a product in
Australia.
There just isn't the market. The electronics industry in Australia is very
small and
altogether somewhat irrelevant in the global scheme of things. Australian
contributions
in electronic innovation have been minimal save for the 'Black Box' flight
recorder perhaps.
Charles L
is
Phil Allison
"Charles L"
can
determine
** Name it and supply a URL.
I am trying to
able to find to date hence my original post.
in
Australia.
small and
contributions
recorder perhaps.
Charles L
** Not just a troll - a fucking arsehole as well.
.......... Phil
H
Heywood Jablome
Phil Allison said:
"Charles L"
What type of metal are IC legs and resistor legs made of? If they are tin,
then whatever eats away at solder also eats away at your IC legs. My guess
is that IC legs are made of copper tinned with tin. Therefore anything that
eats away at your average 60/40 solder will do the same to components.
Trevor Wilson
**Some are copper and some are steel. Most are gold or solder coated.
If they are tin,
that
**Of course. We're still waiting for Charlie's cite.
Charles L
Yes, that's an important consideration that I overlooked. But this product
that I
discovered after doing some searching on the web could be used to clean
solder
off of the PCB without affecting the underlying copper. Removing solder from
the
legs of components will require another method so it seems.
Charles L
Phil Allison
"Charles L"
that I discovered after doing some searching on the web could be used to
clean
solder off of the PCB without affecting the underlying copper. Removing
solder from
the legs of components will require another method so it seems.
Charles L
** Now half way to China by the direct route.
........... Phil
Richard Freeman
can
determine
trying to
able to find
in
Australia.
small and
contributions
recorder perhaps.
What you can only come up with the Black Box ??? without even trying I can
come up with :
The Fairlight CMI/CVI
QPSX Packet switching Technlogy
High resolution Sub Surface Radar (SSR)
The Automatic Totaliser ... Oh hang on that was NZ but then again we claim
NZ Acters/Actresses and Muso's as Aussie
The Bionic Ear
Jindalee
The CSIR mk 1 was considered a world leader at the time
The Electric Drill
Telephane (early Fax machine)
the principles behind Xerox photocopying
The refrigerator
Electronic pacemaker
Teleprinter
In fact given its Relatively small population Australia actually is
significant in terms of inventions on the world stage.
Now on to your original question the only process I can think of that sounds
even vaguley familiar (It does not involve dissolving solder however it is
supposed to be (I have not tried it) a convenient way of removing solder at
relatively low tempratures - In the order of <150C) is a process called
'Co-metalization' described at http://www.zeph.com/process.htm - I believe
Prime electronics in Sydney used to sell this stuff.
Regards
Richard Freeman
