Kevin,
18mA of load current is a lot for most opamps, especially when the load connects to a negative voltage, instead of to ground as is usual.
You don't say which opamp, but a good old 741 is guaranteed to swing its output to only 10V with a 2K load to ground, when using a +, - 15V supply. That's only 5mA. Its output short circuit current is guaranteed to be only 10mA. So your 1K load to -18V will seriously overload the output of a "weak but still guaranteed" 741, and even a typical one that has 25mA of output short circuit current. You can't measure gain when the output is overloaded.
See page 3 of the LM741's data sheet, "Output Voltage Swing" and "Output Short Circuit Current". The data sheet is here:
http://www.national.com/ds/LM/LM741.pdf
You keep saying that your load is a collector resistor. Look at the schematic of the 741 opamp on page 4 of its data sheet and you'll see that the output transistors, Q14 and Q20, are emitter followers that don't have, and don't need, collector resistors.
