Lloyd E. Sponenburgh
- Jan 1, 1970
- 0
There is a local opportunity to buy a used, name brand tow behind
generator that is not working as follows: the engine (4 cyl. White
diesel) is running fine, the generator is not making any output.
I was gifted a nice but non-functional JD estate tractor. 32HP diesel
with all hydrostatic stuff.
The engine runs fine, although I think it's going to need an injector
pump rebuild... stumbles a bit at high speed.
BUT... although every hydraulic accessory on it works perfectly - lift,
blade PTO, accessory PTO, everything - the traction drive will turn the
wheels under no load, but won't move the tractor. You get a little minor
"oommph!" out of it when you attempt to drive, but it won't move in
either forward or reverse.
I noticed that someone had butchered the (very expensive) "neutral"
valves because they were leaking. Thinking this was the problem, I
removed both, replaced o-rings, etc, and _think_ I've made sure the
valves are in the "closed" position (basically welded shut).
Anyone seen this problem? It seems like the pressure is being bypassed
around the traction motor somehow... and the neutral valves still seem to
me like they'd be at the heart of it.
LLoyd
