water level indicator
deepakgupta.rf
Aug 14, 2011
hello everyone
i have made water level indicator based at cd 4066 there we put 4 metal screw and wired to our kit.
in that one is +12v supply and rest three are inputs. and at last one we use relay for loud siren.
but there we are facing trouble with earth problem.there earth making flicking in realy and relay flicking very fastly and we are feared also that is that current we leave in water current can make any trouble when we use water or get any shock.
here i am attaching a file for this but here after bc148 i used a 12 v small relay for siren so this realy is getting flicked.
please solve my problem
poor mystic
Apr 8, 2011
1,106
Hi deepakgupta.rf :)
It's a little hard to penetrate your grammar, which is unique.
However, I wonder where this other current might be coming from and I think you should sort that out first.
PS Be very sure that everything is well earthed!
dauntless
Nov 1, 2013
Hi all, water level indicator based at cd 4066
I have made the below circuit for a school project and found the 4th LED (Full) is not lighting when the full probe touches water level. buzzer is ringing. also all other leds (3) get extinguished. Just extended the reference probe (common 6v) near to the 4th LED (full) probe and extinguishing problem (other 3 leds) solved and still the full led did not light up. any help????:(
hello everyone
shrtrnd
Jan 15, 2010
3,902
Make sure your grounds are correct. As poor mystic mentioned, make sure you're
not picking-up stray current flows. If you've got a voltmeter hooked-up to your circuit,
disconnect it for circuit operation. Any strong electromagnetic fields in the vicinity
of your circuit, move them (Power supplies, other emf generators).
When I built my water/water/level sensor circuit, I found you needed 'dirty' water that
has conductive contaminants in it. The cleaner the water, the less reliable the contact
connections to the 4066. Good luck.
dauntless
Nov 1, 2013
Thanks.
No luck. just removed the full level LED and adjusted the project report with 3 level led and just buzzer for full level.
duke37
Jan 9, 2011
5,364
There will be no danger if you are using an isolated 12V supply.
The 180k resistors could be raised to say 1M if necessary which may make more reliable operation.
The 2.2k feeding the BC148 is very low. The BC148 could be replaced by a fet or a darlington transistor with a high value drive resistor.
A Darlington can be made with a pair of BC148.
More reliability would be achieved if a positive electrode were placed near each sense electrode.
Arouse1973
Adam
Dec 18, 2013
5,178
Why don't you put the buzzer across the 4th LED and resistor and get rid of the transistors? That's assuming is not a 100dB sounder that draws an amp or two :)
Adam
