Watt meter / Power meter / kWh meter
F
flarkblark
FYI--
After searching at length for a watt meter, i.e. to determine
how much power my appliances are using (and to prove that the
power company is reporting bogus information), I discovered
the Kill-a-Watt by Ahern. It costed about $35 and so far
it appears to be functioning perfectly.
Tweetldee
flarkblark said:
FYI--
Yep, that's a nice instrument. I have had one for about a year, and use it
quite often on equipment that I'm working on. Always works, no hassle, no
setup, no calibration. Always ready to go in a few seconds. Good
investment if you need to know those things.
Tweetldee
Tweetldee at att dot net (Just subsitute the appropriate characters in the
address)
Time is what keeps everything from happening all at once.
F
flarkblark
Having one has turned out to be quite interesting. We've resolved
our problem with our power company (they overcharged by a factor of 3),
but using the meter to measure the power use of everyday appliances
has shown that the ratings on the back of devices aren't always accurate.
For instance, a TV rated at 120 VAC and 1.5 amps should use up to 180 watts
using the simple P=VA equation. However it only uses 85 W on average.
Similarly our desktop computer is rated at 240 W but uses about 80 W
even when the CPU is 100% occupied. Meanwhile the printer while it's on
standby is a mere 4 watts.
A laptop computer meanwhile varies quite a lot: running the CPU
at 100% with the screen on uses 55 W; with the screen saver on, 30 W,
and with the screen on but CPU utilization reduced it uses only 23 W.
R.Lewis
flarkblark said:
"Tweetldee" <[email protected]> wrote in message
watts
? Depends on power factor.
It could be zero watts at 1.5 amps (although I *very* much doubt it.)
Mjolinor
watts
No it doesn't, irrespective of the power factor the TV should use up to 180
watts.
W
Watson A.Name - Watt Sun
That's really a rip-off. You should have that one written up in the
newspaper and it should be a consumer piece on your local TV news.
Let everyone else know that they may be getting overcharged, too.
That's the way it should be. The rating should be the absolute
maximum and should never be exceeded, and the normal operating current
should always be lower than the rating.
[snip]
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
R.Lewis
watts.
If the TV is rated at 120VAC and 1.5 amps you have no idea what the watts
are other than it may be any number between 0 and 180.
Mjolinor
Which is exactly what the first post said
H
Harry Conover
Please elaborate on the power company overcharge. How did it happen,
did they correct the source of the error, and did they refund the
amount you were overcharged.
I'm particulary curious about this, as documented events of this sort
of vanishingly rare.
Harry C.
F
flarkblark
Not that rare.
They upgraded our meters for remote sensing and that resulted
in $300/month bills that should have been a third of that.
I guess they wanted to downsize the meter reader people.
If we hadn't complained they would never have fixed the
problem.
H
Harry Conover
Not that rare.
This is a normal upgrade in most parts of the country, and generally
doesn't result in an overcharge.
problem.
So how did they fix the problem, did you get a refund from the
electric company?
Harry C.
F
flarkblark
electric company?
Actually, it appears NOT. We are quite alarmed by the latest bill.
It appears they said one thing and did another.
That's PECO for you.
H
Harry Conover
Picture yourself pounding you head against a rock wall, just to hear
the sound that it makes.
That's what dealing with a utility company is like!
Harry C.
F
flarkblark
Yeah...makes me want to go off-grid.
