watts consumed range as recorded by an APC UPS unit
bjf
can someone comment on this observation:
I replaced an aging UPS which provides some power backup/surge control for a digital
cable box and television, bought this unit
Model: BR1300LCD (APC BACK-UPS RS 1300VA LCD)
When both the cable box and tv are on, the watts on the LCD display alternates between
a low of 87 watts, up to 107 watts at somewhat random intervals but all within a few
minutes.
what might be the reason the watts "change" by this range of about 20 watts?
I have the unit set on a permanent LCD display turned on so it works similar to my
Kill-A-Watt display, though much nicer
V
Vaughn Simon
I have actually seen the same effect on the KAW when it is connected to an
electronic appliance with a switching power supply. What you are seeing is an
artififact of the sampling rate of the wattmeter trying to make sense of the
ragged load presented by a switching power supply. If you stop to think about
it, it is not surprising that a switching power supply "switches" on & off
rather than presenting a steady load. In fact, they work very much like the
mechanical voltage regulators found in the cars of my youth.
Vaughn
M Q
alternates between a low of 87 watts, up to 107 watts at somewhat random
intervals but all within a few minutes.
watts?
The brightness of the picture displayed on the TV at the moment.
You didn't say if the TV was a CRT or newer technology.
CRT uses more power to produce more light, as would, I suspect
plasma, but not LCD.
