Weird LED circuit problem
Wotan
Oct 8, 2011
37
Here's the problem- I have made this circuit-
But as soon as I connect the supply voltage, the LED blinks as it shoud for about 1/2 a second and then stops working altogether. Could this be because the connection from the supply voltage is not very good? I had to replace the battery clip I was using because the wirse on it were too thin and weren't making a proper connection.
DrPinky
Nov 7, 2011
22
You might have burnt out the LED, I tested the circuit on Yenka and it burnt the LED out. BobK is right you probably need a 390 Ohm resistor.
Wotan
Oct 8, 2011
37
I have put a resistor in the circuit, it's still doing exactly the same thing.
1) what value is your resistor?
2) what do you mean "altogether"? (until you cycle power, or until you replace it with a new one?)
Wotan
Oct 8, 2011
37
1)The resistor connected to the LED is 470 ohms.
2) The LED blinks and then fades until it is no longer lit. The LED works ok I have tested on it's own, separately to this circuit.
measure the voltage across the power supply pins (1 and 8) and tell us what is happening.
Wotan
Oct 8, 2011
37
I'll get back to you on that Steve, I need a decent power supply first.
