Weird Voltage divider issue
SparkyCal
Mar 11, 2020
863
So, I have been building this same circuit, a number of ways (see circuit here:https://www.electronicspoint.com/forums/threads/a-stretch.293212/
I used a LM741 op amp and it worked. Did the same circuit, this time incorporating an additional resistor as suggested by AudioGuru- and it worked.
Now I built it using the 4558D op amp. It worked but then when i tried it the next day, it did not. I found that the voltage was not being properly divided by the voltage divider. I found a faulty resistor and replaced it (one of the 10 K ones R33)
Tested it and it indeed dropped the voltage to roughly 4.5 volts. But minutes later, it went back to close to 9 volts. How can that be?
14,294
As usual: show us a circuit schematic with component designators and values. It is real hard to imagine what you're doing. Remember: you'r sitting in front of your circuit, we don't.
SparkyCal
Mar 11, 2020
863
Sorry Harald. This might help further define the issue. I don't need help with the entire circuit. For whatever reason, i have a mental block which causes me to sometimes build the voltage divider correctly, and sometime not. For the ones I have done correctly, they are already glued into stompboxes and it would be messy to take them out to look.
In light of that, I have attached a schematic in which i have circled in red, the part of the circuit that I keep building correctly, and incorrectly. I think i need to look at it in a different way.
I am wondering if someone might be kind enough to draw this part of the circuit in a clearer way that would make it easier for me to interpret. It could even be a hand written drawing on a napkin.
Here is is
14,294
That cannot be helped by looking at the schematic. One would have to see the actual build. From the schematic I can see no obvious reason why R33 should go short circuit.
minutes later, it went backl to close to 9 volts. How can that be?
Check the connection between R33 and R33 and also of the other side of R32 to GND (0 V).
The schematic is clear to me. It shows all components, all connections, no crossings that could be misinterpreted. Which part would you not understand?
Cheers,
Harald
SparkyCal
Mar 11, 2020
863
Hi Harald:
It's a mystery to me because the night prior, the entire pedal was working. The next morning, i try it again and it was not working. I checked the voltages to the pins, and it seemed like the voltage was no longer being divided. I replaced one of the resistors which I thought may have been faulty. The meter showed the voltage properly divided. But that only lasted on measurement. When i tried the pedal, it reverted to full voltage without it being divided.
In light of this, I'm not sure that i mis understood the schematic, or perhaps something else is causing the voltage divider to fail. Not sure if that is even possible.
Perhaps I need to go back to the breadboard to ensure the divider is being assembled properly. as mentioned, have made this pedal a few times, and never had this problem on the others. They still work.
SparkyCal
Mar 11, 2020
863
I drew a pic of how I hooked it up. The dotted circular area is what i am particularly unsure of
bertus
3,857
When using a breadbord, you can have bad contacts that are intermittend when a part is moved.
The contacts in the breadboards are strips that can go bad when a to thick wire has been forced into it.
Read the attached PDF and have a look at the image I post.
Some breadboards have a break in the power lines in the middle of the board:
If you want to make a drawing of a breadboard, you can use Pebble, a third party program from picaxe:
https://picaxe.com/software/third-party/pebble/
Bertus
  • breadboard.pdf
ratstar
Aug 20, 2018
485
Id say it would be R32 that is not connected, by what you said what was happening.
Martaine2005
May 12, 2015
5,306
This implies you are NOT using the breadboard.
How did you connect the components?.
The resistor you replaced, did you measure it with your meter?.
Was it faulty?.
As already mentioned, using thicker wire or thicker legged components in the breadboard will cause bad connections for thinner legged components.
Martin
SparkyCal
Mar 11, 2020
863
You're right. i did not use a breadboard. I used a PCB. The resistor did appear to be faulty after measuring it. When i connected a new one, i got the half voltage- but only momentarily. Then it went to over 8 volts. When i get time I am going to redo this pedal again. I think I'll also move to strip board. There were a lot of wires when i used the PCB and the chances for error and shorts is greater.
SparkyCal
Mar 11, 2020
863
Thank-you folks. What I have concluded is that any of a number of things could have caused this. The major learning from this round, is to use strip board. I used PCB which necessitated a lot more wiring and soldering than had I used strip board. So, i just built the voltage divider on strip board and it works fine. I am going to continue on strip board and see if the end result is a lot tidier and less chaotic.
