what about RF remote controls for servos an data transmission?
Matthias Broersma
hello everybody,
im starting to build a remote controlled catamaran with two engines (one in
each floater). the model will be in large scale, length about 3 meter. the
engines will be derived from big machinery...dont know yet what depends of
expenses...
anyway i will need a way to control remotely this big guy.
requisites are:
- i need to be able do command at least 4 servos (from laptop would be nice)
- i need a range that is not less then 300meters
- i need to send data back from the boat to a laptop (using some kind of
serial connection) for usage with gps and other sensors.
the plans for my boat are all ready and well, i have trouble thoug
understanding this electrical stuff.
i heard of RF remotecontrols...some of them with serial interface.... well i
need all the usefull info i can get.what do i need?how does it work?links
whatever!
Thanks to all
and sorry for my bad english
Matthias
Rich Grise
Matthias Broersma said:
hello everybody,
expenses...
Look into radio controlled modeling. They make all kinds of adapters -
I actually worked with a unit that used a standard RC channel, with
a motor controller - it plugs into the servo jack, and instead
of position, the joystick controls speed. That channel would need
some kid of fail-safe, because when those RC receivers lose the
signal, the servos hold position, which means that the motor
controller holds the motor at the same speed. I made it happen
once.
And the circuitry of their servos could be adapted to any size,
or you could take their signal and roll your own.
Have Fun!
Rich
Tim Auton
once.
R/C modelers (the ones with the bigger planes usually) use safety
cut-outs, which will set the position (speed) to a pre-determined
point when the signal dies. Find them at R/C flying shops specializing
in large-scale models.
If you want to go for electric power, you might want to look at some
websites for fighting "robots" (BattleBots, Robot Wars etc.) - they
have plenty of experience in using standard R/C kit to control big
electric motors.
For a petrol engine it's easy - get one with a centrifugal clutch
(from a lawn mower, for example) and stick a servo on the throttle.
Tim
