What charger to use for LI-ion batteries
Ian Wallis
Nov 13, 2017
23
Hello all, My old laptop battery pack died, and after removing the dead Li-ion cells I'm left with 8 usable. So to put them to good use, I have a 6 volt florescent tube type lantern I'd like to use two of the 3.6volt CGR18650AF cells in.
But what do I recharge them with?
Ideally charging from my 12 volt solar system (car battery) would be nice.
Thank you for any help you can give.
Here's a data sheet http://www.houseofbatteries.com/documents/CGR18650AF.pdf
Alec_t
Jul 7, 2015
3,820
Welcome to EP!
Lithium batteries are fussy and need a particular charging profile if they are to be charged safely. If charged wrongly they can catch fire or explode:eek:.
Have a read of this.
There are special-purpose ICs available for safely controlling the charge profile.
kellys_eye
Jun 25, 2010
6,512
The 18650 is a 'generic' Lithium, very commonly used these days and there are dedicated chargers for them as well as simple circuit board modules for charging them singly, in pairs, in series etc.
Google '18650 charger' and see what comes up.
Ian Wallis
Nov 13, 2017
23
Thank you for the info guys. Silly but I just didn't realize Joe public used these Lithium batteries, as all I ever see is AA nickel metal hydride.
Anyhow ebay's a wash with everything that I would need, a 12 volt car charger for 99p :) Sorted, Cheers.
WHONOES
May 20, 2017
1,242
Li-Ion cells have to be charged in a similar manner to sealed Lead Acid batteries.
This is a 3 term process.
The charge voltage should be set depending on the construction of the battery. Those with cathodes of Aluminium, Cobalt, Nickel or Manganese require 4.2V per cell though some Nickel based varieties will require just 4.1V per cell.
The 3 term process is constant current then constant voltage followed by a maintenance charge.
The constant current part is to prevent excessively large amounts of current being dumped into your depleted battery which would cook it in no time at all and would most likely catch fire. A value of 0.5 to 1 times cell capacity would be required.
Then as the cells accrue charge they will come to a point where the current will start to diminish whereupon constant voltage charging takes over.
When charge current drops to 10% or so, the charge voltage would be reduced to the cells nominal voltage which provides the maintenance aspect of the process.
This probably sound like a design nightmare but is actually quite simple to implement.
WHONOES
May 20, 2017
1,242
Don't use a 12V car charger it is not up to it.
kellys_eye
Jun 25, 2010
6,512
Why not?
A single 18650 is only needs a 4.2V (give or take) charge voltage and a module powered from 12V would have no difficulty with that.
WHONOES
May 20, 2017
1,242
Yes but, you still need to regulate the output volts to 4.2V per cell.
Audioguru
Sep 24, 2016
3,656
My 18650 Lithium Ion cells from a laptop are name-brand (Panasonic) and are rated at 3000mAh (3A).
I adjusted an LM317 regulator to an output of 9.1V and it has a 1N4002 rectifier diode in series with its output so that the circuit output is 8.4V. It is powered from a 12VDC/1A wall wart. Two of the cells replace four Ni-Cad cells in a portable vacuum cleaner and I charge the lithium cells overnight when the vacuum cleaner runs slow.
