What current is drawn by LED mains night light?
Don Klipstein
Blue looks subjectively a lot dimmer to the eye even though the photon
energy is higher. But having said that I suspect what causes the LEDs in
this circuit to fade is damage inflicted by fast mains transients and
inductive spikes on the mains.
Compared to incandescent filament bulbs they are fabulously reliable -
and in many modern display applications have excellent collimation built
in. Signs on motorways that are highly visible from a long way off but
do not dazzle nearby drivers are one major application.
I can't recall ever seeing a neon indicator that has failed without
being smashed. I have some lying around from decades ago that still
work. Laser tubes seem to expire more easily.
I see lots of neons either fade to extreme dimness or start flickering
and then gradually become "less on" and "more off" in their flickering as
they age. The flickerers eventually go completely out. My experience is
that a neon glow lamp indicator is usually in bad shape after less than a
decade of use.
Don Klipstein
That 250mW seems higher than I expected. The LED would draw only a
fraction of that and I hadn't expected the supporting circuitry to
need so much power.
LED nightlights often have a bridge rectifier and a current limiting
capacitor in series with one of the AC leads of the bridge rectifier. In
addition, there is usually a series resistor to limit inrush current, and
a resistor in parallel with the current limiting capacitor to discharge it
so that the prongs of the lightlight cannot cause a shock after unpluging
it. My experience is that these two resistors combined often dissipate
much more power than the LED does.
Joerg
Peter said:
Seems there are many different circuits one could use. I hadn't
anticipated so many!
http://www.cappels.org/dproj/ledpage/leddrv.htm
Those aren't for mains-powered lights. With batteries you can get even
lower. IIRC the lowest useful conversion I got was at around 350mV
battery voltage, using an RF JFET. I think it was the BF862. Warning to
anyone trying this: Be careful. Sloppy wiring can make that JFET sing
like a bird and disturb radio bands. You may not even notice such
oscillation because it is able to happily do its intended job at the
same time.
Jon Kirwan
<SNIP failures other than of phosphors>
Believe me, the inorganic phosphors do degrade in LEDs from photons of
energies 3 eV or a bit less.
Can you name any specific ones that do? I use phosphors of various
types and I haven't experienced any that degrade that much (to the
point of complete failure for purpose like this.) If you mean degrade
in a different sense, then perhaps we are talking cross-purposes.
Part of the problem may be contamination from other ingredients in the
LED.
Are you talking about migration into the phosphor? Or something that
has nothing to do with the phosphors used? I'm confused about your
meaning here.
Light intensity of tens of watts per square centimeter, a couple orders
of magnitude more intense than in fluorescent lamps (where phosphor life
is usually only 10,000's of hours also), is almost certainly part of
this issue.
I assume you are talking about these high-wattage LED cases? Although
I don't have experience with them (or phosphors used in that
circumstance), I have two thoughts. (1) The web site was talking
about night lights, for gosh sake. (2) If the rare earth phosphor is
to degrade, you are talking about dissassociation, aren't you? That
is primarily a function of eV, not intensity. Though it may increase
the odds of two photons stacking into a dissassociation event, I
suppose.
I know you can attempt to 'argue' this, but frankly it goes against
many years of practical experiences I've had. I admit I haven't used
high wattage LED sources, but I've used xenon flash lamps quite a lot
in combination with various phosphors for.. almost 20 years now. These
lamps have the highest luminance of any light source you can name
excepting perhaps some lasers. Those are serious sources and I've
used them in continuous situations for decades without needing to
change out the phosphor target. I just don't buy the argument.
Like I said, although I can imagine possibilities, my experience flies
in the face of the idea of a mere night light LED using a rare earth
phosphor with 3 eV photons completely failing to provide visible light
levels for human night vision in 3 months being due to the phosphor
itself degrading to that point. I just cannot go there. The stuff
has to have been chemically unstable to begin with, or poisoned in
some way. There are materials which will quench the effect.
Jon
Joerg
some way. ...
That's probably the key sentence here. There are threading dislocations,
plain old thermal runaway because of surface inconsistencies,
contaminations, etc. Considering the price of such lights the
manufacturers would probably hump every opportunity to scrape off half a
penny by going to a different "distributor". And who knows where the
stuff is really coming from. I have heard from people who had plain old
jelly-bean opamps and similar chips do weird things. Leakage increases
that couldn't be explained, and so on. In most cases they had been
bought at, ahem, second tier sources.
Jon Kirwan
some way. ...
Thermal runaway in a night light???
Well, some phosphors are very cheap stuff. I don't know how much they
use in these LEDs, but in my applications a pound of it will last for
tens of thousands of probes (.02 gram each.) Of course, they don't
sell for 10 cents a piece. But cripes, it's not expensive.
Combustion synthesis began to be used in the late 1980's, I think. The
method is cheap (ammonium nitrate oxidizer and urea or glycine fuels)
and produces well-crystallized, very fine particle sizes very rapidly
and often without the necessity of very high temps in a separate step
(meaning above say 1500C) needed for annealing; or other expensive
steps like mechanical separation (grinding, milling, etc., which also
have the downside of often quenching the effect in the product.) It's
a mature, production process producing a cheap, uniform product so far
as I know.
And who knows where the stuff is really coming from.
Well, this is why I started asking in the first place. I'm just
sitting here flummoxed about the idea of a weak night light LED
phosphor getting completely destroyed by a few 3 eV photons over its
occasional use in a 3 month time. Every aspect of that tells me
something is wrong with the claim. The photon energies just don't cut
it. The low intensities just don't cut it. The short calendar time
just doesn't cut it. The complete loss of function doesn't make any
sense, either. And rare-earth phosphors are about as stable as a
piece of ceramic tile. They don't have _any_ H2O in them -- their
formation temperatures make darned sure that isn't the case. And I
have to buy the whole idea when there are so many reasons why it
shouldn't be able to happen?
I'm not saying it can't. Like everyone else, I live a tiny life span
in a small, narrow part of the world and I do not have comprehensive
experience. Something could certainly surprise me. So that's why I
was asking about it. I'd really like to know exactly _what_ the
phosphor is. Then I could go over to the books on my shelves and take
a look, at least, to see if that makes sense in this context.
I guess it's like telling me that sometimes a rock falls upwards. I
might believe it, if I knew what kind of exact rock it was. (Filled
with a hydrogen gas??) But I'd sure have a hard time buying it if
someone didn't spend a little time describing the rock.
Hehe. I have had similar, unexplained behaviors in really good
quality Burr-Brown chips. The ACF2101, for example. I would sit and
monitor the integrator output for weeks at a time. It would sit
wonderfully at one charge level for many minutes, then suddenly shift
to a figure 3 times higher and stay there for another 5 or 10 minutes,
then suddenly shift to a third value different from the other two, and
then cycle around these three places. I was using a stock demo board
from Burr-Brown in these tests, which was pretty well designed and
made up in effect a faraday cage for it, too. One of the weird things
was that the stepped levels were at discrete places. No level in
between was every hit. It was as though there were a few stable
places where the bias current could sit and that it would randomly
jump from place to place and just sit there for a while. Then move
again. The time between jumps appeared to be rather Gaussian in
distribution, too. (One of the things I looked at and why I ran this
for a few weeks.)
But that has nothing to do with the phosphors. I completely accept
the idea that some manufacturers don't care at all and will cheat
anywhere they can get away with it, even if only for a few months at a
stretch. That's definitely believable. But phosphors are pretty
stable from my modest experiences and I'm still struggling with all of
the combined factors of the claim on that web site. I'll believe it,
but I'll need to know what the phosphor is. I'm really curious about
that aspect.
Jon
Paul Keinanen
I bought a bunch of cool blue led night lights, a year or so ago, and
set one aside as a reference to check against once in a while. No
visible diff so far. Must have got lucky.
What is the point of using blue in night lights ?
Blue light will inhibit the melatonin production, so it may help wake
early in the morning.
However, if the intention is to continue sleeping, after being awake
for while in the middle of the night, blue is a bad idea.
OTOH, if the intention is to maintain night vision (scotopic vision),
red light is used e.g. for reading maps while navigating, since rods
do not respond to red and hence does not destroy the dark adaptation.
For best subjective effectiveness, the spectral peak (683 lm/W) at
moderate to high intensity levels is at 555 nm (yellowish green), but
for a dark adapted eye, the sensitivity peak (1700 lm/W) is around 507
nm (bluish green). In fact, the scotopic sensitivity is over 685 nm
for 445 .. 555 nm.
http://hyperphysics.phy-astr.gsu.edu/hbase/vision/efficacy.html
Paul
K
krw
But the federales in most places have caught on to that :-(
The other side of that coin is that if it doesn't interfere (as much
as one that doesn't) because it's dithering, who cares?
Charmed Snark
I.N. Galidakis expounded in
Martin Brown wrote:
[snip]
work.
OTOH, I haven't seen many in power bars that still work. They
are either:
1) Expired or
2) Sputtering themselves to expiry
Man, I hate them.
Snark.
JosephKK
On Sun, 27 Sep 2009 11:09:13 -0700 (PDT), linnix
[snip]
There is one advantage of LED over CFL. LED lights can be focused to
a distance where light is required. For example, we have high
ceilings in the house. CFL are bright at the ceiling, but dim on the
floor. LED can light up the floor much better than CFL.
We also have very high ceilings, 12' to 16'.
Would it be better to use a white LED or make white light with blue,
green and red LED's?
...Jim Thompson
That is a tradeoff. I would use LEDs over a lot of varied wavelengths
in addition to phosphor white LEDs.
What's in a modern car's headlights?
...Jim Thompson
At over US$1000 per unit for LED headlights i am not going to DPA a
working unit just to find out.
Charmed Snark
Martin Brown wrote:
[snip]
work.
are either:
1) Expired or
Man, I hate them.
Do you know how to quote attributions correctly?
I didn't write any of the above. In fact my response was exactly about
"sputtering".
Please be careful WHO you quote and HOW.
Don't you know how to read? The problem is
upstream. I just replied to it.
Snark.
