What Gauge Copper Wire Should I Use?
roonyroo
Jul 13, 2012
13
Im trying to build a simple electric generator using magnets & bare copper wire, what gauge copper wire should I use?
I was thinking of getting 16 gauge copper wire, for around a 500 turn coil, or would I be better off with a thicker wire?
Could I use tin plated copper wire? Would a plated wire be better then a regular bare copper wire?
Im new to electronics, need all the help I can get lol
thnx
duke37
Jan 9, 2011
5,364
You cannot use bare wire in a coil since conduction between turns will short out the coil.
Enamelled wire (magnet wire) is the way to go.
A few turns of thick wire will give a low voltage and a high current, a lot of turns of thin wire will give a high voltage but a low current. The power in both cases will be similar and will depend on the magnetic circuit.
szhighstar
Aug 7, 2012
6
suggest to use PEW wire, A=I/J, A is section across area of wire, I is current, J is current density, you can select J is 3A/mm*mm.
