What Glue
Kermet
Oct 18, 2009
13
Hi, Im looking for the name of the light brown glue used to hold down Caps and on wire to
relief the strain,
I don’t wont to use hot glue
does that brown stuff last years ?
if not what else could I use ?
I just want it for wire relief
hoping to get it at RS components
cheers
Brett
shrtrnd
Jan 15, 2010
3,902
Don't know what 'brown glue' you're referring to.
A lot of what you need will depend on the heat the board is exposed to.
No necessarily the heat of the components you intend to glue-down.
Is the circuit going to be in a cabinet or enclosure that will get hot?
Rixen
Feb 16, 2016
98
Just checked..
We use something called Dow Corning 744 at work.
I think RS carries that brand too, maybe you could get that.
Kermet
Oct 18, 2009
13
@Rixen....yes that is the Neutral Cure silicon...i was after the brown pva type that you see on wires
its this stuff on the wires
for some reason I cant post the link with the time in the video so fast forward to 3m5s
Minder
Apr 24, 2015
3,561
That's what I use, RTV or Silicone rubber caulk,
It is also easy to remove, should the need be to replace a component.
M.
shrtrnd
Jan 15, 2010
3,902
I'll mention, a lot of the circuits you see coming out of China, they are allowed to use whatever they want (no chemical MSDS requirements). Your brown glue might just be what is cheap and easy to get wherever your controllers were manufactured.
Kermet
Oct 18, 2009
13
I wonder if i can add something to PVA glue..... ?
Rixen
Feb 16, 2016
98
What's so speciel about that brown stuff? I mean, we are talking about securing some wires.
Now you want to start mixing something. Why not just use, an off-the-shelf solution, that's made for just these sort of things?
The stuff i talked about earlier. IS used in production (In the end product) on capacitors, inductors, varistors, whatever. I see no reason it cant work on holding down a wire. The place I work ship millions of products every month with that stuff in them.
Edit: davenn beat me to it :eek:
Kermet
Oct 18, 2009
13
I dont like RTV,
It does not last long once the tube has been open/pieced also its not that cheap here
Ive used hot glue before and not easy if you want to service/work on the item again and remove
I understand why RTV is used in production but I might only use it 4 times a year maybe, not practical for me.
If no one knows what the brown stuff is called thats fine
14,484
I dont like RTV,
yes that is a valid response
so use white or clear silicone sealer ... pretty cheap in small tubes from your fav hardware store
What is wrong with hot glue?
that's also valid .... personally I wouldn't use hot glue, unless I had absolutely nothing else available
