What is a USB to Serial Converter? Overview of USB to Serial Converter
ilianaboone
Aug 11, 2023
37
A USB to Serial Converterhttps://www.cdebyte.com/Modem-CommunicationConverter-USBtoSerialConverter is a converter used to connect a device with a USB interface to a device with a serial port (such as RS232, RS485, or RS422). This converter is widely used in the communication needs between modern computers and traditional serial devices, especially when many modern computers are no longer equipped with traditional serial ports.
Related article:
RS232/RS485 serial port communication introduction
Difference Between Serial port and Parallel Port
Classification and Application of Serial Port Baud Rate
USB to Serial Converter Functions and Uses
Protocol Conversion: Convert USB protocols to serial protocols (RS232, RS485, RS422), enabling modern computers to communicate with traditional serial devices.
Interface Expansion: Provides a serial port interface for devices without serial ports (such as laptops, tablets), expanding their connection capabilities.
Data Transfer: Supports bidirectional data transmission, enabling real-time communication between USB devices and serial devices.
USB to Serial Converter Features
Plug and Play: Most USB to Serial Converters support plug and play, and can be used without complicated settings after being plugged in.
Driver Support: Drivers for multiple operating systems are usually provided, including Windows, macOS, and Linux, ensuring wide compatibility.
Multiple serial port types
Support multiple serial port standards, such as RS232, RS485 and RS422, to meet different application requirements.
Power supply
Usually powered by USB port, no external power supply required, easy to use.
Portability
Small size, easy to carry and use, suitable for on-site debugging and mobile office.
Application scenarios
Industrial automation:
Connect computers with industrial equipment such as PLC, sensors, actuators, etc. to achieve data acquisition and control.
Medical equipment:
Connect medical equipment (such as monitors, laboratory equipment) to computers for data recording and analysis.
Communication system:
During communication testing and debugging, connect modems, routers and other devices for data transmission and monitoring.
Equipment maintenance:
Connect devices for fault diagnosis, firmware updates and parameter configuration.
EBYTE USB to serial converter recommendation
Explore EBYTE high-performance communication converter series, including RS485 hubs, USB-to-serial converters, industrial bus converters and isolation converters. We provide professional solutions to meet your industrial communication needs, supporting efficient data processing and secure transmission.
E810-U15C
E810-U15https://www.cdebyte.com/products/E810-U15
