charmcaster.engg
- Mar 20, 2014
- 79
- Joined
- Mar 20, 2014
- Messages
- 79
If the load in the given circuit is 80 k
The current flowing through an unloaded voltage divider is bleeder current.Which component is the 'bleeder resistor'?
Can you explain in detail how you have find out the current? I tried but I didn't get it.I get 1.96mA through R2. I obtained this by first calculating the output voltage. It would then seem that the bleeder current is the wasted current through R2
The question is to find bleeder current. No additional details.It would seem that whoever calculated the answer of 1.96 mA was using a different definition.
Was the question to find the bleeder current, or find the current through the bleeder resistor?
Find the voltage across RL from the voltage divider between R1 and {R2 in parallel with RL}, then use that voltage to get the current through R2....explain in detail how you have find out the current...
Thanks!Find the voltage across RL from the voltage divider between R1 and {R2 in parallel with RL}, then use that voltage to get the current through R2.
