What Is List In Program
Status
Not open for further replies.
vead
Nov 27, 2011
473
Hello
This code is source file of list. generally List means the number of items. I want to understand what is use of this program ? why do we need this source file ?
Code:
#include <stdlib.h>
#include "FreeRTOS.h"
#include "list.h"
void vListInitialise( xList * const pxList )
    /* The list structure contains a list item which is used to mark the
    end of the list.  To initialise the list the list end is inserted
    as the only list entry. */
    pxList->pxIndex = ( xListItem * ) &( pxList->xListEnd );            /*lint !e826 !e740 The mini list structure is used as the list end to save RAM.  This is checked and valid. */
    /* The list end value is the highest possible value in the list to
    ensure it remains at the end of the list. */
    pxList->xListEnd.xItemValue = portMAX_DELAY;
    /* The list end next and previous pointers point to itself so we know
    when the list is empty. */
    pxList->xListEnd.pxNext = ( xListItem * ) &( pxList->xListEnd );    /*lint !e826 !e740 The mini list structure is used as the list end to save RAM.  This is checked and valid. */
    pxList->xListEnd.pxPrevious = ( xListItem * ) &( pxList->xListEnd );/*lint !e826 !e740 The mini list structure is used as the list end to save RAM.  This is checked and valid. */
    pxList->uxNumberOfItems = ( unsigned portBASE_TYPE ) 0U;
void vListInitialiseItem( xListItem * const pxItem )
    /* Make sure the list item is not recorded as being on a list. */
    pxItem->pvContainer = NULL;
void vListInsertEnd( xList * const pxList, xListItem * const pxNewListItem )
xListItem * pxIndex;
    /* Insert a new list item into pxList, but rather than sort the list,
    makes the new list item the last item to be removed by a call to
    pvListGetOwnerOfNextEntry. */
    pxIndex = pxList->pxIndex;
    pxNewListItem->pxNext = pxIndex;
    pxNewListItem->pxPrevious = pxIndex->pxPrevious;
    pxIndex->pxPrevious->pxNext = pxNewListItem;
    pxIndex->pxPrevious = pxNewListItem;
    /* Remember which list the item is in. */
    pxNewListItem->pvContainer = ( void * ) pxList;
    ( pxList->uxNumberOfItems )++;
void vListInsert( xList * const pxList, xListItem * const pxNewListItem )
xListItem *pxIterator;
portTickType xValueOfInsertion;
    /* Insert the new list item into the list, sorted in ulListItem order. */
    xValueOfInsertion = pxNewListItem->xItemValue;
    if( xValueOfInsertion == portMAX_DELAY )
        pxIterator = pxList->xListEnd.pxPrevious;
    else
        for( pxIterator = ( xListItem * ) &( pxList->xListEnd ); pxIterator->pxNext->xItemValue <= xValueOfInsertion; pxIterator = pxIterator->pxNext ) /*lint !e826 !e740 The mini list structure is used as the list end to save RAM.  This is checked and valid. */
            /* There is nothing to do here, we are just iterating to the
            wanted insertion position. */
    pxNewListItem->pxNext = pxIterator->pxNext;
    pxNewListItem->pxNext->pxPrevious = pxNewListItem;
    pxNewListItem->pxPrevious = pxIterator;
    pxIterator->pxNext = pxNewListItem;
    /* Remember which list the item is in.  This allows fast removal of the
    item later. */
unsigned portBASE_TYPE uxListRemove( xListItem * const pxItemToRemove )
xList * pxList;
    pxItemToRemove->pxNext->pxPrevious = pxItemToRemove->pxPrevious;
    pxItemToRemove->pxPrevious->pxNext = pxItemToRemove->pxNext;
    /* The list item knows which list it is in.  Obtain the list from the list
    item. */
    pxList = ( xList * ) pxItemToRemove->pvContainer;
    /* Make sure the index is left pointing to a valid item. */
    if( pxList->pxIndex == pxItemToRemove )
        pxList->pxIndex = pxItemToRemove->pxPrevious;
    pxItemToRemove->pvContainer = NULL;
    ( pxList->uxNumberOfItems )--;
    return pxList->uxNumberOfItems;
Status
