H
Hammy
- Jan 1, 1970
- 0
90VAC to 140VAC INPUT, 33Vdc out 10A.
Half-Bridge Push-Pull Converter or two switch forward.
How about:
Multiphase Cuk converter.
A real easy design is to take a cheap, off-the-shelf class D amp chip,
and put an oscillator in front of it to drive your output stage with a
nice sine wave. Put a feedback loop in to push the "volume control".
Make a super clean, low ripple linear fed by what is technically a
switcher inside the amp chip. Even if you only run it at like 17kHz, the
chip is at like 400kHz sample rate inside. This 'noise' can be detected
in your output if not managed properly.
What is that?
2 Cuks with opposing ripple?
I thought it rhymed with "buck", a la, one rev. higher than a BuckI thought it was pronounced chewk.
Rhymes with puke.
Cuk-a-doodle-do.Sheeeesh! I was only trying to be a little funny ;-)
...Jim Thompson
I've noticed that most controller ICs seem to be for non-cuk
topologies. (Or perhaps it can be used but Cuk is not mentioned.)
By any chance you know a nice controller chip for a Cuk supply?
I need a supply that can vary from 10% to 80% duty.
It appears that google lost my earlier reply
Booster chips.
Lets see if this works.
is a Cuk. ;-)
Cheers!
Rich
