What is the name of the governing body on industrial standardisation (standardization) in USA?
Jim Gregory
That's your Homeland Security dept - launched after 9/11, surely?
Jim
Jim Gregory
NIST sounds like it's the all-embracing Federal or Central body of
standardising different knots of know-how.
This'll do me for now!
Jim
John Larkin
Jim
No, FEMA has been around for ages. They help out after big disasters:
hurricanes, earthquakes, tornadoes, floods, new Madonna movies, stuff
like that.
John
martin griffith
I don't understand. What's funny about 230V clearances on a pcb ?
I *loved* UL's Hot Flaming Oil test though. They were clearly a bunch of
pyromaniacs !
Graham
TUV said that they wanted X mm clearance on some tracks, no prob,but
it was a very tight layout. I had a really enjoyable time doing it.
Then they said what if they make the boards wrong, ie too small, by
10%, in the photo process, so can you increase the clearance by 10%.
But I said if the board was 10% smaller it wouldnt fit on the
mounting holes and most of the components wouldnt fit, and we would
reject them. Nope they said....
The client must have got the "straight out of college" engineer
martin
Opinions are like assholes -- everyone has one
John Woodgate
I read in sci.electronics.design that martin griffith
<[email protected]>) about 'What is the name of
USA?', on Tue, 29 Mar 2005:
TUV said that they wanted X mm clearance on some tracks, no prob,but it
was a very tight layout. I had a really enjoyable time doing it. Then
they said what if they make the boards wrong, ie too small, by 10%, in
But I said if the board was 10% smaller it wouldnt fit on the mounting
holes and most of the components wouldnt fit, and we would reject them.
Nope they said....
Well, they should not have. They are not supposed to assume that
anything that is documented will not be AS documented. (But the extent
to which they can pile up worst-worst-worst... combinations of
*permitted* variations has never been tested, AFAIK.) So unless your PCB
drawings had no tolerances on dimensions (or tolerances over 10%) they
were out-of-order.
John Woodgate
I read in sci.electronics.design that Tim Shoppa
(standardization) in USA?', on Tue, 29 Mar 2005:
Joke answers:
Federation of European Motorcycle Associations?
Farm Equipment Manufacturers Assocation?
In the US, there really isn't anything like BSI or DIN.
NIST is the closest if you insist on a government agency, but they
don't really do the same thing (although they do a lot!). The
acronymical replacement of NBS with NIST might make you think that
they'll do more technological standards but they don't.
I thought NIST was more like our (UK) National Physical Laboratory,
which is a national 'standards' body with a different meaning of
'standard'... the UK standard metre, volt, amp, ohm etc. live there.
The NPL campus is very interesting. It contains an apparently infinite
number of standard acres, and the time taken to find your way around it
without a map is one standard fortnight.
K
Keith Williams
Joke answers:
NIST does indeed publish such standards. FIPS-140 (Federal Information
Processing Standards number 140) was the standard we used to design
commercial crypto gear. The Fed likes their own standards. ;-)
martin griffith
were out-of-order.
Something i never considered is:
I normally sent gerbers to the client, who passed them onto China with
a screendump/print of the PCB, showing possible DRC's, my comments,
etc. The gerbers effectively ARE the documentation, arnt they?
How do you put tolerances in a gerber file? I'm not really au fait
with gerber format, I just press the button to generate the files and
check that they read out in a third party viewer, say GC Preview.
I just assumed that there are no tolerances in a gerber file.
Sorry if this seems a little dumb
martin
Jim Thompson
I read in sci.electronics.design that John Larkin
Thank you. I will worship there daily. (;-)
I wouldn't if I were you. FEMA has ABSOLUTELY NOTHING to do with
standards... they only coordinate the multi-organization handling of
emergencies.
...Jim Thompson
John Woodgate
I read in sci.electronics.design that Jim Gregory
Funnily enough, in the UK we do not have an equivalent body to your UL.
Well, we do, but it doesn't do electrical products (yet!). It's the Loss
Prevention Council, and it was, like UL, set up by the insurance
industry. Safety of 'consumer electronics' was, however, handled by
British Standards (in BS 415) from 1931; the first edition covered only
mains-supplied 'battery eliminators'.
On this side of the pond, most houses are not wood-framed (except in old
Norwegian villages, where the 'frames' tended to be 30 to 60 cm square
baulks which would not burn easily!), so our electrical safety standards
have tended to concentrate on electric shock rather more than on fire
prevention. In a land of 120 V mains and timber-framed houses, it's not
surprising that UL has opposite priorities.
John Woodgate
How do you put tolerances in a gerber file? I'm not really au fait with
gerber format, I just press the button to generate the files and check
It's the sort of trap you can fall into when your priority is doing the
job rather than providing formal documentation.
In the days before CAD, PC artworks were made with black tape, N-times
full size, with fiduciary marks labelled 'Reduce to X.00 mm +/- 0.1 mm'
or something like that. Our quality people DID sample check a few key
dimensions on the printed boards as well as the fiduciary, to make sure
the boards weren't tilted in the camera or the lens system was out of
spec. We did occasionally get 'tilted' boards.
If your procedures using CAD can't provide equivalent checks, then TUV
have a case. A critical clearance MIGHT be 10% down (if, for example 10%
is 0.4 mm), because your procedures don't have any way to detect that.
OTOH, if your procedures DO cover that, TUV don't have a case.
John Woodgate
I read in sci.electronics.design that Jim Thompson
emergencies.
Note the hyperbolic verb, and the smiley.
Guy Macon
UL doesn't do house wiring. That's NEC (National Electrical Code) country.
UL does product-safety testing and certification.
See [ http://www.ul.com/about/index.html ].
UK is single phase 230V and neutral, right? Split phase 115-neutral-115
(230 total) wiring would have about the same shock potential as the US
system.
John Woodgate
I read in sci.electronics.design that Guy Macon
<[email protected]>) about 'What is the name of the
governing body on industrial standardisation (standardization) in USA?',
country. UL does product-safety testing and certification. See [
I know that. UL is concerned with appliances burning up. Look at all the
stuff in IEC 60950 about 'fire enclosures'. That's almost all derived
form UL.
115-neutral-115 (230 total) wiring would have about the same shock
potential as the US system.
But you are less likely to touch both 'lives' than one 'live' and
neutral or ground.
Jim Gregory
Any country that uses 110V -120V in domestic (and commercial premises)
wiring must use twice as much copper and brass by weight in infrastructure
as needed for a 220V - 240V supply, based on same MegaWatts of lighting and
power used (wasteful is that trend).
National EHV grid potentials are the same most of the world, but after
comparative distribution, the halved step-down voltage seems uneconomical in
practice.
Incidentally, to come into line with other places, we have dropped our AC
line specification from 240V to 230V in the last twelve years.
ELCBs or RCDs can trip very quickly indeed if exposed live mains is touched
accidentally.
For the very reason you suggested, some temporary-site safety step-down
transformers give 115V centre-tapped, but it is not *standard* here yet, but
no safety earth (a separate neutral) is possible with a balanced system,
unless 4-pole connectors are adopted.
Question
If a house fire were blamed on the failure of a piece of AC equipment that
turned out forensically not to have UL (or LPC) certification, and the
occupier had paid his insurance premium, would resulting fire damage claims
for contents and property still be paid out nevertheless?
governing body on industrial standardisation (standardization) in USA?', on
Tue, 29 Mar 2005:
stuff in IEC 60950 about 'fire enclosures'. That's almost all derived form
UL.
system.
But you are less likely to touch both 'lives' than one 'live' and neutral
or ground.
Regards, John Woodgate, OOO - Own Opinions Only.
There are two sides to every question, except
'What is a Moebius strip?'
http://www.jmwa.demon.co.uk Also see http://www.isce.org.uk
Tue, 29 Mar 2005:
UL.
system.
or ground.
In Britain it is the BSI.
In Germany it is DIN.
The ISO is multi-national.
The European Union now has the CEN.
What is the closest central technical authority in the USA?
There's not a single agency. There are many government and civillian
agencies that provide "guidelines" which may be incorporated into legal
codes (such as electrical or building codes). Some of thse are:
NFPA - Nat'nl Fire Prevention Assn.
ASTM - American Socity for Testing and Materials
ANSI - American Nat'nl Standards Inst.
ASM - American Society of Metals
SAE - Society of Automotive Engineers
ASME - American Society of Manufacturing Engineers
Plus the myriad alphabet soup of govt. agencies.
John Larkin
practice.
accidentally.
Balanced 240 would certainly work. In the US, big appliances like air
conditioners and clothes driers in fact use 240 volts with a 3-prong
plug: 120/120/ground. That's actually the ideal circuit: it has the
low shock properties of US 120, but the low fire hazard of European
240.
Question
Of course. Nothing but self-inflicted arson would void an insurance
policy.
John
Rich The Newsgropup Wacko
When guns are outlawed, only the:
Accounting and Auditing Policy Committee (AAPC)
Acquisition Department
Acquisition and Assistance Management Services
Administration and Resource Management
Administration for Children and Families
Administration on Aging
Administrative Committee of the Federal Register
Administrative Law Judges
Administrative Office of the U.S. Courts (Federal Judiciary Homepage)
Administrative Offices
Administrator
Advanced Technology Program
Advisory Committee on Student Financial Assistance
Advisory Council on Historic Preservation
Aeronomy Laboratory
African Development Foundation
African and Middle Eastern Reading Room
AgExport Services Division
Agency for Healthcare Research and Quality
Agency for Toxic Substances and Disease Registry
Agricultural Labor Affairs Coordinator
Agricultural Marketing Service
Agricultural Research Service -ARS
Air Combat Command
Air Education and Training Command
Air Force Agency for Modeling and Simulation
Air Force Audit Agency
Air Force Center for Environmental Excellence
Air Force Civil Engineer Support Agency
Air Force Communications Agency
Air Force Historical Research Agency
Air Force History Support Office
Air Force Information Warfare Center
Air Force Inspection Agency
Air Force Institute of Technology
Air Force Legal Services Agency
Air Force Materiel Command
Air Force Medical Operations Agency
Air Force Medical Support Agency
Air Force News Agency
Air Force Office of Scientific Research
Air Force Office of Special Investigations
Air Force Office of Survivor Assistance
Air Force Personnel Center
Air Force Real Property Agency
Air Force Research Laboratory
Air Force Reserve Command
Air Force Reserve Officer Training Corps (AFROTC)
Air Force Reserve Personnel Center
Air Force Safety Center
Air Force Services Agency
Air Force Space Command
Air Force Special Operations Command
Air Force Studies and Analyses Agency
Air Force Technical Applications Center
Air Intelligence Agency
Air Mobility Command
Air National Guard
Air Quality Branch
Air Resources Division
Air Resources Laboratory
Air University
Air Weather Service
Aircraft Technology
Albuquerque Operations Office
Alcohol and Tobacco Tax and Trade Bureau
Alternative Farming Systems Information Center
American Battle Monuments Commission
American Folklife Center
American Forces Information Service
American Indian Liaison Office
American Indian and Alaska Native Affairs Desk
American Memory
Ames Laboratory (AMES)
Ames Research Center
Anacostia Museum and Center for African American History and Culture
Animal Welfare Information Center
Animal and Plant Health Inspection Service
Antitrust Division
Appalachian Regional Commission
Architect of the Capitol
Architectural and Transportation Barriers Compliance Board (Access Board)
Archives of American Art
Arctic Research Commission
Argonne National Laboratory (ANL)
Armed Forces Radiobiology Research Institute (AFRRI)
Armed Forces Retirement Home
Army Financial Management
Army Materiel Command
Army Medical Department (AMEDD)
Army Research Laboratory (ARL)
Army Review Boards Agency (ARBA)
Arthritis and Musculoskeletal Interagency Coordinating Committee
Arthur M. Sackler Gallery
Arts and Industries Building
ArtsEdge
Asian Division Reading Room
Assistant Secretary Fish and Wildlife and Parks
Associate Administrator for Commercial Space Transportation
Atlantic Oceanographic and Meteorological Laboratory
Barry M. Goldwater Scholarship and Excellence in Education Foundation
Benefits Review Board
Bettis Atomic Power Laboratory
Board of Contract Appeals
Board of Governors of the Federal Reserve System
Board of Veterans' Appeals
Border and Transportation Security
Boston Region
Branch of Acknowledgment and Research
Broadcasting Board of Governors
Brookhaven National Laboratory
Building and Fire Research Laboratory
Bureau for International Narcotics and Law Enforcement Affairs
Bureau of Administration
Bureau of African Affairs
Bureau of Alcohol, Tobacco, Firearms, and Explosives
Bureau of Arms Control
Bureau of Consular Affairs
Bureau of Democracy, Human Rights, and Labor
Bureau of Diplomatic Security
Bureau of East Asian and Pacific Affairs
Bureau of Economic Analysis (BEA)
Bureau of Educational and Cultural Affairs (ECA)
Bureau of Engraving and Printing
Bureau of European and Eurasian Affairs
Bureau of Indian Affairs
Bureau of Industry and Security
Bureau of Intelligence and Research
Bureau of International Labor Affairs
Bureau of Justice Assistance
Bureau of Justice Statistics
Bureau of Labor Statistics
Bureau of Land Management
Bureau of Legislative Affairs
Bureau of Medicine and Surgery
Bureau of Naval Personnel
Bureau of Near Eastern Affairs
Bureau of Nonproliferation
Bureau of Oceans and International Environmental and Scientific Affairs
Bureau of Political Military Affairs
Bureau of Population, Refugees, and Migration
Bureau of Prisons
Bureau of Public Affairs
Bureau of Reclamation
Bureau of Resource Management
Bureau of South Asian Affairs
Bureau of Transportation Statistics
Bureau of Western Hemisphere Affairs
Bureau of the Census
Bureau of the Public Debt
Business Reference Services
Carlsbad Area Office
Cataloging Directorate
Cataloging Distribution Service
Cataloging Policy and Support Office (CPSO)
Cataloging in Publication Division
Center for Biologics Evaluation and Research (CBER)
Center for Cost and Financing Studies
Center for Devices and Radiological Health
Center for Drug Evaluation and Research
Center for Earth and Planetary Studies (CEPS)
Center for Faith-Based Initiatives
Center for Folklife and Cultural Heritage
Center for Food Safety and Applied Nutrition
Center for Information Technology
Center for Organization and Delivery Studies
Center for Outcomes and Effectiveness Research
Center for Pirmary Care Research
Center for Practice and Technology Assessment
Center for Quality Improvement and Patient Safety
Center for Scientific Review
Center for Veterinary Medicine
Center for the Book
Centers for Disease Control and Prevention
Centers for Medicare and Medicaid Services
Central Intelligence Agency (CIA)
Chemical Safety and Hazard Investigation Board
Chemical Science and Technology Laboratory
Chicago Region
Chief Financial Officers Council
Chief Information Officer
Chief Information Officers Council
Chief Procurement Officer
Chief of Naval Operations
Children's Literature Center
Citizens' Stamp Advisory Committee
Civil Air Patrol
Civil Division
Civil Rights Division
Civil Rights
Climate Diagnostics Center
Climate Monitoring and Diagnostics Laboratory
Clinical Center
Coast Guard
Coastal Habitat Conservation Programs
Cognitive, Neural and Biomolecular Science and Technology Division
Cold Regions Research and Engineering Laboratory
Command, Control, Communications, Computers
Commandant of the Marine Corps
Commission of Fine Arts
Commission on Security and Cooperation in Europe (Helsinki Commission)
Committee for Purchase from People Who Are Blind or Severely Disabled
Committee for the Implementation of Textile Agreements
Committee on Foreign Investment in the United States
Commodity Futures Trading Commission (CFTC)
Community Development Financial Institutions Fund
Community Relations Service
Compliance Review Staff
Congressional Budget Office (CBO)
Congressional Research Service
Construction Engineering Research Laboratories(CECER)
Consumer Product Safety Commission (CPSC)
Contract Reform and Privatization Office
Cooper-Hewitt National Design Museum
Coordinating Council on Juvenile Justice and Delinquency Prevention
Corporate Programs Division
Corporation for National and Community Service
Cotton, Oilseeds, Tobacco and Seeds Division
Council of Economic Advisers
Council on Environmental Quality
Courts of Appeal/Federal Court Finder
Criminal Division
Critical Infrastructure
Customer Service: Departmental Account Representative Division
D.C. Circuit via FindLaw
D.C. Circuit via Georgetown University Law Center
DLA Office of Operations Research and Resource Analysis (DORRA)
Dairy, Livestock and Poultry Division
Dallas Region
Defense Acquisition University
Defense Administrative Support Center
Defense Advanced Research Projects Agency (DARPA)
Defense Commissary Agency (DeCA)
Defense Contract Audit Agency (DCAA)
Defense Contract Management Agency (DCMA)
Defense Contract Management District International (DCMDI)
Defense Contract Management District West (DCMDW)
Defense Courier Service
Defense Distribution Center (DDC)
Defense Energy Support Center (DESC)
Defense Finance and Accounting Service (DFAS)
Defense Human Resources Activity
Defense Industrial Supply Center (DISC)
Defense Information Systems Agency (DISA)
Defense Intelligence Agency (DIA)
Defense Legal Services Agency
Defense Logistics Agency (DLA)
Defense Logistics Information Service (DLIS)
Defense Logistics Support Command (DLSC)
Defense National Stockpile Center (DNSC)
Defense Nuclear Facilities Safety Board (DNFSB)
Defense Prisoner of War/Missing Personnel Office
Defense Reutilization and Marketing Service (DRMS)
Defense Security Cooperation Agency (DSCA)
Defense Security Service (DSS)
Defense Supply Center Columbus (DSCC)
Defense Supply Center Philadelphia (DSCP)
Defense Supply Center Richmond (DSCR)
Defense Technical Information Center (DTIC)
Defense Threat Reduction Agency (DTRA)
Delaware River Basin Commission
Democratic Caucus
Democratic Leadership
Democratic Whip
Denver Region
Department of Agriculture
Department of Commerce
Department of Defense (DefenseLINK)
Department of Defense Education Activity
Department of Education
Department of Energy
Department of Health and Human Services
Department of Homeland Security
Department of Housing and Urban Development (HUD)
Department of Justice
Department of Labor (DOL)
Department of State
Department of Transportation
Department of Veterans Affairs
Department of the Air Force
Department of the Army
Department of the Interior
Department of the Navy Environmental Program
Department of the Treasury
Departmental Appeals Board
Departmental Representative to the Defense Nuclear Facilities Safety Board
Deputy Chief Financial Officer
Director, Marine Corps Staff
Directorate for Command, Control, Communications, and Computer System (J-6)
Directorate for Intelligence (J-2)
Directorate for Manpower and Personnel (J-1)
Directorate for Operations
Directorate of Educational Policy and Development
Directorate of Integration
Directorate of Management
District Courts
District Offices
Division of Bird Habitat Conservation
Division of Contracting and General Services
Division of Endangered Species
Division of Energy and Mineral Resources
Division of Environmental Contaminants
Division of Federal Aid
Division of Federal Employees' Compensation
Division of Finance
Division of Forestry
Division of Health Assessment and Consultation
Division of Health Education and Promotion
Division of Health Studies
Division of Information Technology Management
Division of Law Enforcement
Division of Longshore and Harbor Workers' Compensation
Division of Migratory Bird Management
Division of Policy and Directives Management
Division of Public Affairs
Division of Realty
Division of Toxicology
Document Automation and Production Service
Domestic Policy Council
Drug Enforcement Administration (DEA)
Dryden Flight Research Center
Dwight D. Eisenhower Library and Museum
Economic Development Administration
Economic Research Service
Economics and Statistics Administration
Educational Partnerships Program
Educational Resources Information Center (ERIC)
Eighth Circuit via FindLaw
Eighth Circuit
Eighth U.S. Army
Electronics Division
Electronics and Electrical Engineering Laboratory
Eleventh Circuit Published Opinions
Eleventh Circuit via Emory University School of Law
Eleventh Circuit via FindLaw
Eleventh Wing
Employee Benefits Security Administration
Employees' Compensation Appeals Board (ECAB)
Employment Standards Administration
Employment and Training Administration
Endangered Species Committee
Energy Efficiency and Renewable Energy
Energy Information Administration (EIA)
Energy Sciences Network (ESnet)
Enforcement Center
Engineering Materials and Physical Science
Environmental Measurement Laboratory (EML)
Environmental Protection Agency (EPA)
Environmental Research Laboratories
Environmental Studies Program Information System
Environmental Technology Laboratory
Epidemiology Program Office
Equal Employment Opportunity Commission (EEOC)
Equal Employment Opportunity Office
Ernest Orlando Lawrence Berkeley National Laboratory (LBNL)
Ethics Office
European Command
European Reading Room
Evidence-based Practice Centers
Executive Office for Asset Forfeiture
Executive Office for Immigration Review
Executive Office for United States Attorneys
Executive Office for Weed and Seed
Executive Office of the President
Export Administration Review Board
Export-Import Bank of the United States
FBI Laboratory
FWS Data Administration
Facilities and Leadership
Family Policy Compliance Office
Farm Credit Administration
Farm Service Agency
Farm and Foreign Agriculture Services
FedWorld Information Network
Federal Accounting Standards Advisory Board (FASAB)
Federal Aviation Administration (FAA)
Federal Bureau of Investigation (FBI)
Federal Circuit via Emory University School of Law
Federal Circuit via FindLaw
Federal Circuit via Georgetown University Law Center
Federal Communications Commission (FCC)
Federal Computer Incident Response Center
Federal Deposit Insurance Corporation (FDIC)
Federal Depository Library Program Administration (FDLP)
Federal Duck Stamp Office
Federal Election Commission (FEC)
Federal Emergency Management Agency FEMA
Federal Energy Management Program
Federal Energy Regulatory Commission (FERC)
Federal Executive Board
Federal Executive Institute and Management Development Centers
Federal Financial Institutions Examination Council
Federal Financing Bank
Federal Highway Administration
Federal Housing Finance Board
Federal Interagency Committee for the Management of Noxious and Exotic Weed
Federal Interagency Committee on Education
Federal Job Announcement Search
Federal Judicial Center
Federal Junior Duck Stamp Conservation and Design Program
Federal Labor Relations Authority
Federal Laboratory Consortium for Technology Transfer
Federal Lands Highway Office
Federal Law Enforcement Training Center
Federal Library and Information Center Committee
Federal Maritime Commission
Federal Mediation and Conciliation Service
Federal Mine Safety and Health Review Commission
Federal Railroad Administration
Federal Relay Service
Federal Research Division
Federal Reserve Bank of Atlanta
Federal Reserve Bank of Boston
Federal Reserve Bank of Chicago
Federal Reserve Bank of Cleveland
Federal Reserve Bank of Dallas
Federal Reserve Bank of Kansas City
Federal Reserve Bank of Minneapolis
Federal Reserve Bank of New York
Federal Reserve Bank of Philadelphia
Federal Reserve Bank of Richmond
Federal Reserve Bank of San Francisco
Federal Reserve Bank of St. Louis
Federal Retirement Programs
Federal Retirement Thrift Investment Board
Federal Supply Service
Federal Technology Service (formerly Federal Telecommunications Service)
Federal Trade Commission (FTC)
Federal Transit Administration
Fermi National Accelerator Laboratory (Fermilab)
Fernald Environmental Management Project
Field Offices
Fifth Circuit via FindLaw
Financial Crimes Enforcement Network
Financial Management Service
Fire Management
Fire and Aviation Management
First Circuit via Emory University School of Law
First Circuit via FindLaw
Fish and Wildlife Reference Service
Flight Standards Service
Fogarty International Center
Food Safety Information Center
Food Safety and Inspection Service
Food and Drug Administration
Food and Nutrition Information Center
Food and Nutrition Service
Food, Nutrition, and Consumer Services
Force Structure, Resources and Assessment Directorate (J-8)
Forecast Systems Laboratory
Foreign Claims Settlement Commission
Foreign Investment Survey
Foreign Service Institute
Forest & Fishery Products Division
Forest Service
Fourth Circuit via Emory University School of Law
Fourth Circuit via FindLaw
Franklin D. Roosevelt Presidential Library and Museum
Freer Gallery of Art
GITS Security
GPO Online Bookstore
Gateway to Government Food Safety Information
General Services Administration (GSA)
Geographic Data Service Center
Geographic Information Systems and Spatial Data
Geography and Map Division (G&M)
Geological Resources Division
Geophysical Fluid Dynamics Laboratory
George Bush Presidential Library and Museum
Gerald R. Ford Library and Museum
Glenn Research Center
Goddard Institute for Space Studies
Goddard Space Flight Center
Golden Field Office
Government Accountability Office
Government Domain Registration and Services
Government Information Xchange (GIX)
Government National Mortgage Association (Ginnie Mae)
Government Printing Office (GPO)
Grain Inspection, Packers and Stockyards Administration
Great Lakes Environmental Research Laboratory
Great Lakes and Ohio River Division
Great Plains Region
Hanford Site
Harry S. Truman Scholarship Foundation
Headquarters United States Air Force
Headquarters, United States Marine Corps
Health Resources and Services Administration
Health Services
Herbert C. Hoover Building Library
Herbert Hoover Presidential Library and Museum
High Performance Computing and Communications (HPCC)
Hirshhorn Museum and Sculpture Garden
Hispanic Reading Room
History and Museums Division
Horticultural and Tropical Products Division (H&TP)
House Leadership Offices
House Majority Whip
House Republican Conference
House Republican Policy Committee
Human Resources Center
Human Resources Management
Human Systems Department
Idaho National Engineering and Environmental Laboratory (INEEL)
Idaho Operations Office
Illinois and Michigan Canal National Heritage Corridor Commission
Immeidate Office of the Director
Import Administration (IA)
Independent Validation and Verification Facility
Indian Arts and Crafts Board
Indian Health Service (IHS)
Industrial College of the Armed Forces
Industrial and Corporate Programs
Information Analysis and Infrastructure Protection
Information Electronics and Surveillance Department
Information Management and Information Technology
Information Operations
Information Resource Center
Information Resources Management College
Information Security Oversight Office
Information Technology Laboratory
Information Technology Solutions
Information/Publications
Infrastructure Protection and Computer Intrusion Squad (WFO IPCIS)
Infrastructure
Inspector General
Installations and Logistics Department
Institute for Federal Printing and Electronic Publishing
Institute for Telecommunications Sciences
Institute of Education Services
Institute of Museum and Library Services
Insurance Service
Inter-American Foundation
Internal Revenue Service (IRS)
International Cultural Property Protection
International Field Office
International Trade Administration
J. William Fulbright Foreign Scholarship Board
James Madison Memorial Fellowship Foundation
Japan Documentation Center
Japan-United States Friendship Commission
Jet Propulsion Laboratory
Jimmy Carter Library and Museum
John Fitzgerald Kennedy Library and Museum
Johnson Space Center
Joint Board for the Enrollment of Actuaries
Joint Chiefs of Staff
Joint Forces Command
Joint Forces Staff College
Joint Military Intelligence College
Judicial Panel on Multidistrict Litigation
Justice Information Center
Justice Management Division
Kansas City Plant (Allied Signal Inc)
Kansas City Region
Kennedy Space Center
Knolls Atomic Power Laboratory (KAPL)
Langley Research Center
Law Library of Congress
Lawrence Livermore National Laboratory (LLNL)
Legal Services Corporation
Library of Congress Online Public Access Catalog
Library of Congress
Loan Guaranty Service
Local History & Genealogy
Local Offices
Logistics Directorate (J-4)
Los Alamos National Laboratory (LANL)
Lower Colorado Region
Lydon Baines Johnson Library and Museum
Main: Humanities & Social Sciences
Management Assistance Team
Management Service Office
Manpower and Reserve Affairs
Manufacturing Engineering Laboratory
Manufacturing Extension Partnership
Manufacturing Technology Division
Manuscript Division
Mapping and Analysis for Public Safety
Marine Corps Combat Development Command
Marine Corps Recruiting Command
Marine Corps Systems Command
Marine Corps Uniform Board
Marine Expeditionary Units
Marine Mammal Commission
MarineLink Websites
Maritime Administration
Market Access Compliance (MAC)
Marketing and Regulatory Programs
Marshall Space Flight Center
Materials Management Service (MMS)
Materials Science and Engineering Laboratory
Materials Science and Technology Division
Mathematical, Computer, and Information Sciences Division
Measurement and Standards Laboratories
Mechanics and Energy Conversion Science and Technology Division
Medical Science and Technology Division
Medicare Payment Advisory Commission
Merit Systems Protection Board
Miamisburg Environmental Management Project (Mound)
Microform Reading Room
Mid-Pacific Region
Migratory Bird Conservation Commission
Mike Monroney Aeronautical Center
Mine Safety and Health Administration
Minerals Management Service
Minerals and Geology Management
Minority Business Development Agency
Missile Defense Agency
Mississippi River Commission
Mississippi Valley Division
Moffett Federal Airfield
Morris K. Udall Scholarship and Excellence in National Environmental Policy Foundation
Motion Picture and Television Reading Room
Motor Carrier and Highway Safety
NASA Centers
NASA Headquarters
National Aeronautics and Space Administration (NASA)
National Agricultural Library
National Agricultural Statistics Service
National Air and Space Museum
National Applied Resource Sciences Center
National Arboretum
National Arboretum
National Archives Trust Fund Board
National Archives and Records Administration (NARA)
National Assessment of Educational Progress
National Bipartisan Commission on the Future of Medicare
National Business Center (NBC)
National Cancer Institute
National Capital Planning Commission
National Cemetery Administration (NCA)
National Center for Chronic Disease Prevention and Health Promotion
National Center for Complementary and Alternative Medicine
National Center for Education Evaluation and Regional Assistance (NCEE)
National Center for Education Research
National Center for Education Statistics (NCES)
National Center for Environmental Health
National Center for HIV, STD, and TB Prevention
National Center for Health Promotion and Disease Prevention
National Center for Health Statistics
National Center for Infectious Diseases
National Center for Injury Prevention and Control
National Center for Minority Health and Health Disparities
National Center for Research Resources
National Center for Toxicological Research (NCTR)
National Center on Birth Defects and Developmental Disabilities
National Chaplain Center
National Climatic Data Center (NCDC)
National Commission on Libraries and Information Science
National Communications System
National Conservation Training Center
National Council on Disability
National Credit Union Administration (NCUA)
National Criminal Justice Reference Service
National Defense University
National Drug Intelligence Center
National Economic Council
National Endowment for the Arts
National Endowment for the Humanities (NEH)
National Energy Technology Laboratory (NETL)
National Environmental Satellite, Data, and Information Service (NESDIS)
National Eye Institute
National Finance Center
National Gallery of Art
National Geophysical Data Center (NGDC)
National Geospatial-Intelligence Agency
National Guard
National Guideline Clearinghouse
National Heart, Lung, and Blood Institute
National Highway Traffic Safety Administration (NHTSA)
National Historical Publications and Records Commission
National Human Genome Research Institute
National Human Resource Management Center (NHRMC)
National Ice Center
National Immunization Program
National Indian Gaming Commission
National Information Resource Management Center
National Information Technology Center
National Infrastructure Protection Center (NIPC)
National Institute for Occupational Safety and Health
National Institute of Alcohol Abuse and Alcoholism
National Institute of Allergy and Infectious Diseases
National Institute of Arthritis and Musculoskeletal and Skin Diseases
National Institute of Biomedical Imaging and Bioengineering
National Institute of Child Health and Human Development
National Institute of Corrections
National Institute of Dental and Craniofacial Research
National Institute of Diabetes and Digestive and Kidney Disease
National Institute of Environmental Health Sciences
National Institute of General Medical Sciences
National Institute of Justice
National Institute of Mental Health
National Institute of Neurological Disorders and Stroke
National Institute of Nursing Research
National Institute of Standards and Technology
National Institute on Aging
National Institute on Deafness and Other Communication Disorders
National Institute on Disability and Rehabilitation Research
National Institute on Drug Abuse
National Institutes of Health
National Interagency Fire Center
National Invasive Species Council
National Labor Relations Board (NLRB)
National Law Enforcement and Corrections Technology Center (JustNet)
National Library Service for the Blind and Physically Handicapped (NLS)
National Library of Education
National Library of Medicine
National Marine Fisheries Service (NMFS)
National Mediation Board
National Mine Health and Safety Academy
National Museum of African Art
National Museum of American History
National Museum of Natural History
National Museum of the American Indian
National Nuclear Security Administration
National Ocean Service (NOS)
National Oceanic and Atmospheric Administration (NOAA)
National Oceanographic Data Center (NODC)
National Park Foundation
National Park Service NatureNet
National Petroleum Technology Office (NPTO)
National Portrait Gallery
National Postal Museum
National Quality Program
National Railroad Passenger Corporation (Amtrak)
National Reconnaissance Office
National Renewable Energy Laboratory
National Research and Development Centers
National Response Center
National Rural Development Partnership (NRDP)
National Science Foundation (NSF)
National Security Agency/Central Security Service
National Security Council
National Severe Storms Laboratory
National Technical Information Service (NTIS)
National Telecommunications and Information Administration
National Training Center
National Transportation Library
National Transportation Safety Board
National War College
National Weather Service (NWS)
National Wetlands Inventory
National Wild Horse and Burro Program
National Wildlife Refuge System
National Zoological Park
Natural Resources Conservation Service
Naval Criminal Investigative Service
Naval Expeditionary Warfare
Naval Petroleum Reserve
Naval Research Laboratory
Naval Space Science & Technology Program Office
Navigation Center
Navy Science and Technology Ship Office
Nevada Operations Office
Nevada Test Site
New Brunswick Laboratory (NBL)
New York Region
Newspaper and Current Periodical Room
Ninth Circuit via FindLaw
Nixon Presidential Materials
Nonproliferation and Disarmament Fund
North American Waterfowl and Wetlands Office
North Atlantic Division
Northern Command
Northwest Power and Conservation Planning Council
Northwestern Division
Nuclear Incident Response Team
Nuclear Regulatory Commission (NRC)
Oak Ridge Institute for Science and Education
Oak Ridge National Laboratories
Oak Ridge Operations (ORO)
Oak Ridge Operations' Environmental Management Program
Oakland Operations Office
Occupational Health and Environmental Services (OHES)
Occupational Safety and Health Administration (OSHA)
Occupational Safety and Health Review Commission
Ocean Atmosphere and Space Department
Office for Civil Rights
Office for Domestic Preparedness
Office for Human Resources
Office for Public Health Emergency Preparedness
Office for Victims of Crime
Office of Acquisition and Materiel Management
Office of Acquisition and Property Management
Office of Administration
Office of Administrative Law Judges
Office of Advanced Scientific Computing Research OCTR
Office of Aircraft Services
Office of Allowances
Office of American Indian Trust
Office of Applied Science
Office of Asset Management
Office of Authentication
Office of Biological and Environmental Research
Office of Boating Safety
Office of Bridge Technology
Office of Budget and Management Services
Office of Budget and Program Analysis
Office of Budget
Office of Business Innovations (OBI)
Office of Business Liaison
Office of Chief Financial Officer
Office of Chief Information Officer
Office of Children's Health
Office of Citizen Services and Communications
Office of Civilian Radioactive Waste Management(RW)
Office of Communications
Office of Community Development
Office of Community Oriented Policing Services (COPS)
Office of Community Planning and Development
Office of Compliance
Office of Comptroller
Office of Congressional Affairs
Office of Congressional Relations
Office of Congressional and Intergovernmental Affairs
Office of Congressional and Intergovernmental Relations
Office of Congressional and Legislative Affairs
Office of Congressional and Public Affairs
Office of Crisis Planning and Management
Office of Defense Programs (DP)
Office of Defense Trade Controls
Office of Departmental Operations and Coordination
Office of Disability Employment Policy
Office of Disease Prevention and Health Promotion
Office of Dispute Resolution
Office of Domestic Finance
Office of Economic Adjustment
Office of Economic Impact and Diversity
Office of Educational Partnerships
Office of Elementary and Secondary Education (OESE)
Office of Energy Assurance
Office of Enforcement
Office of English Language Acquisition, Language Enhancement, and Academic Achievement for Limited English Proficient Students
Office of Environment, Safety and Health (EH)
Office of Environmental Management (EM)
Office of Equal Opportunity Program
Office of Ethics
Office of Executive Secretariat
Office of Extramural Research, Education, and Priority Populations
Office of Fair Housing and Equal Opportunity
Office of Faith-Based and Community Initiatives
Office of Federal Contract Compliance Programs
Office of Federal Housing Enterprise Oversight
Office of Federal Programs
Office of Federal Student Aid
Office of Field Policy and Management
Office of Finance: Electronic Funds Transfer Enrollment and W-9 Forms
Office of Financial Management
Office of FirstGov
Office of Fissile Materials Disposition
Office of Fossil Energy
Office of General Counsel
Office of Genomics and Disease Prevention
Office of Global Programs
Office of Government Ethics
Office of Governmentwide Policy
Office of Hearings and Appeals
Office of Housing/Federal Housing Authority (FHA)
Office of Human Resources
Office of Independent Oversight & Performance Assurance (OA)
Office of Indian Education Programs
Office of Information Resources Management
Office of Information and Privacy
Office of Information and Technology
Office of Innovation and Improvement
Office of Inspector General
Office of Insular Affairs
Office of Intelligence Policy and Review
Office of Intergovernmental and Interagency Affairs
Office of Intergovernmental and Public Liaison
Office of International Affairs
Office of International Information Programs (IIP)
Office of International Trade
Office of Justice Programs
Office of Juvenile Justice and Delinqunecy Prevention
Office of Labor Relations
Office of Labor-Management Standards
Office of Law Enforcement
Office of Lead Hazard Control
Office of Legal Counsel
Office of Legal Policy
Office of Legislation and Congressional Affairs
Office of Legislative Affairs
Office of Legislative and Congressional Affairs
Office of Management and Administration (MA)
Office of Management and Budget
Office of Managing Risk and Public Safety
Office of Multifamily Housing Assistance Restructuring
Office of National AIDS Policy
Office of National Customer Services Management
Office of National Drug Control Policy
Office of Native American Affairs
Office of Naval Research
Office of Non-Public Education
Office of Nonproliferation and National Security (NE)
Office of Nuclear Energy, Science, and Technology (NN)
Office of Nursing Services
Office of Occupational Safety and Health
Office of Oceanic and Atmospheric Research
Office of Organizational Resources
Office of Overseas Schools
Office of Pavement Technology
Office of Performance Budgeting
Office of Personnel Management
Office of Personnel Policy
Office of Personnel
Office of Planning and Performance Management
Office of Policy Development and Research
Office of Policy Management and Budget
Office of Policy and External Affairs
Office of Policy and International Affairs
Office of Policy, Management and Budget
Office of Postsecondary Education (OPE)
Office of Procurement
Office of Professional Responsibility
Office of Program Operations and Management
Office of Program and Policy Services
Office of Protocol
Office of Public Affairs
Office of Public Health and Science
Office of Public and Indian Housing
Office of Real Property Asset Management
Office of Regional Operations
Office of Regulatory Affairs
Office of Research and Development
Office of Research and Technology Applications (ORTA)
Office of Risk Assessment and Cost-Benefit Analysis (ORACBA)
Office of Safe and Drug-Free Schools
Office of Satellite Data Processing and Distribution
Office of Science and Technology Policy
Office of Scientific and Technical Information
Office of Security and Emergency Operations (SO)
Office of Self-Governance
Office of Small Business Programs
Office of Small and Disadvantaged Business Utilization
Office of Special Counsel (OSC)
Office of Special Education Programs
Office of Special Education and Rehabilitative Service
Office of Surface Mining Reclamation and Enforcement
Office of System Safety
Office of Technology Assessment
Office of Technology Services
Office of Thematic Programs
Office of Thrift Supervision
Office of Tribal Services
Office of Trust Responsibilities
Office of Under Secretary for Arms Control and International Security Affairs
Office of Under Secretary for Economic, Business, and Agricultural Affairs
Office of Under Secretary for Global Affairs
Office of Under Secretary for Management
Office of Under Secretary for Public Diplomacy and Public Affairs
Office of Under Secretary of Defense for Acquisition and Technology(ACQWeb)
Office of Urban Affairs
Office of Veterans Business Development
Office of Vocational and Adult Education (OVAE)
Office of Women's Business Ownership
Office of Worker and Community Transition (WT)
Office of Workers' Compensation Programs
Office of the Assistant Secretary for Administration and Management
Office of the Assistant Secretary for Policy
Office of the Associate Administrator for Airports
Office of the Associate Administrator for Science
Office of the Associate Attorney General
Office of the Attorney General
Office of the Chief Architect
Office of the Chief Economist
Office of the Chief Financial Officer
Office of the Chief Information Officer (CR)
Office of the Circuit Executive--Official Ninth Circuit Web Site
Office of the Clerk
Office of the Commissioner
Office of the Comptroller of the Currency
Office of the Coordinator for Counterterrorism
Office of the Deputy Attorney General
Office of the Executive Secretariat
Office of the Federal Detention Trustee
Office of the First Lady
Office of the Historian
Office of the Inspector General
Office of the Legal Adviser
Office of the Majority Leader
Office of the Naval Inspector General
Office of the Pardon Attorney
Office of the Permanent Representative to the United Nations
Office of the Procurement Executive
Office of the Secretary of Defense
Office of the Senior Coordinator for International Women's Issues
Office of the Solicitor General
Office of the Speaker of the House
Office of the Special Trustee for American Indians
Office of the Under Secretary of Defense (Comptroller)
Office of the Under Secretary of Defense for Personnel and Readiness
Office of the Vice President of the United States
Official D.C. Circuit Web Site
Official Federal Circuit Website
Official Fifth Circuit Website
Offshore Minerals Management Program (OMM)
Ohio Field Office (OH)
Operational Plans and Interoperability Directorate (J-7)
Operations
Overseas Private Investment Corporation
Overseas Security Advisory Council (OSAC)
Pacific Air Forces
Pacific Command
Pacific Marine Environmental Laboratory
Pacific Northwest National Laboratory (PNL)
Pacific Northwest Region
Pacific Ocean Division
Panama Canal Commission
Pantex Plant: Nuclear Weapons Assembly and Disassembly Facility
Pasture Systems and Watershed Management Research Lab (PSWMRL)
Patent and Trademark Office
Peace Corps
Pension Benefit Guaranty Corporation
Pentagon Force Protection Agency
Performing Arts Reading Room
Philadelphia Region
Photoduplication Service
Physical Medicine and Rehabilitation Service
Physical Sciences Science and Technology Division
Physics Laboratory
Planning and Environment
Plans, Policies and Operations
Plum Island Animal Disease Center
Policy Planning Staff
Postal Rate Commission
Preservation Directorate
Preservation Reformatting Division
President's Council on Integrity and Efficiency
President's Council on Sustainable Development
President's Foreign Intelligence Advisory Board
Presidential Libraries
Presidential Scholars Program
Presidio Trust
Princeton Plasma Physics Laboratory
Printing Procurement Department
Prints and Photographs Reading Room
Processes and Prediction Division
Procurement
Product Innovation Division
Production Department
Production Estimates and Crop Assessment Division
Professional Responsibility Advisory Office
Program Support Center
Programs and Resources
Property Management
Public Buildings Service
Public Health Practice Program Office
Public Relations
Quality Control and Technical Department
Railroad Retirement Board
Ralph J. Bunche Library
Rare Book and Special Collections Reading Room
Reading Rooms
Real Estate Assessment Center
Recorded Sound Reference Center
Region 1 (Pacific Region)
Region 2 (Southwest Region)
Region 3 (Great Lakes-Big Rivers Region)
Region 4 (Southeast Region)
Region 5 (Northeast Region)
Region 6 (Mountain-Prairies Region)
Region 7 (Alaska Region)
Regional Offices
Regulatory Information Service Center
Rehabilitation Services Administration
Renwick Gallery
Representatives on the Web
Research Facilities
Research and Special Programs Administration
Research, Education and Economics
Richland Operations Office (RL)
Risk Management Agency
Rocky Flats Environmental Technology Site
Rocky Flats Field Office (RFFO)
Ronald Reagan Presidential Library
Rural Business-Cooperative Service
Rural Development
Rural Housing Service
Rural Information Center
Rural Utilities Service
STAT-USA (formerly Office of Business Analysis)
Safety Division
Saint Lawrence Seaway Development Corporation
San Francisco Region
Sandia National Laboratories
Savannah River Ecology Laboratory
Savannah River Operations Office
Savannah River Site (Westinghouse)
Science Reading Room
Seattle Region
Second Circuit via FindLaw
Second Circuit via Touro Law Center
Secretary of Energy Advisory Board
Secretary of State
Secretary of the Interior
Secretary's Representatives
Securities and Exchange Commission (SEC)
Select Committee on Technology Transfer to the People's Republic of China
Selective Service System
Senate Historical Office
Senators on the Web
Senior Executive Service
Sensing and Systems Division
Sergeant Major of the Marine Corps
Seventh Circuit via FindLaw
Seventh Circuit
Ship Hull, Mechanical, and Electrical Systems Science and Technology Division
Simplified Tax and Wage Reporting System (STAWRS)
Sixth Circuit via Emory University School of Law
Sixth Circuit via FindLaw
Small Business Administration (SBA)
Small Business Innovation Research (SBIR)/Small Business Technology Transfer (STTR) Division
Smithsonian American Art Museum
Smithsonian Astrophysical Obesrvatory
Smithsonian Institution
Social Security Administration (SSA)
Social Security Advisory Board
South Atlantic Division
South Pacific Division
Southern Command
Southwestern Division
Space Environment Center
Staff Judge Advocate to the Commandant
Stanford Linear Accelerator Center (SLAC)
State Justice Institute
State Offices
Stennis Center for Public Service
Stennis Space Center
Strategic Command
Strategic Petroleum Reserve
Strategic Plans and Policy Directorate (J-5)
Strike Technology Division
Study of the U.S. Branch
Substance Abuse and Mental Health Services Administration
Subtropical Agricultural Research Laboratory
Superintendent of Documents
Supreme Court via FindLaw
Supreme Court via The Oyez Project
Surface Transportation Board
Surveillance, Communications, and Electronic Combat Division
Susquehanna River Basin Commission
THOMAS Legislative Information
TRICARE Management Activity
Tax Division
Technical Service Center
Technology Administration
Technology Services
Tennessee Valley Authority
Tenth Circuit Clerk--Official Tenth Circuit Website
Tenth Circuit via Emory University School of Law
Tenth Circuit via FindLaw
Tenth Circuit via Washburn University School of Law
The Center for Electronic Records
Third Circuit via FindLaw
Third Circuit via Villanova Center for Information Law and Policy
Thomas Jefferson National Accelerator Facility
Topographic Engineering Center
Trade Information Center
Transportation Administrative Service Center (TASC)
Transportation Command
Transportation Security Administration
Tribal Affairs Office
Truman Presidential Library and Museum
U.S. Air Forces in Europe
U.S. Citizenship and Immigration Services
U.S. Coast Guard Auxiliary
U.S. Commercial Service
U.S. Commission for the Preservation of America's Heritage Abroad
U.S. Geological Survey (USGS)
U.S. Government Blue Pages
U.S. House of Representatives
U.S. Immigration and Customs Enforcement
U.S. Missions Online
U.S. Patents Database at CNIDR
U.S. Preventive Services Task Force (USPSTF)
U.S. Senate
U.S. Trade and Development Agency
U.S. Trustee Program
US Army Corps of Engineers
US Fish and Wildlife Forensics Lab, Ashland, Oregon
US Fish and Wildlife Service
USA Jobs
Uniformed Services University of the Health Sciences
Unitd States Court of Appeals for Veterans Claims
United States Air Force Academy
United States Botanic Garden
United States Coast Guard Academy
United States Commission on Civil Rights
United States Copyright Office
United States Court of Appeals for the Ninth Circuit
United States Court of Federal Claims
United States Court of International Trade
United States Customs and Border Protection
United States Holocaust Memorial Museum
United States Institute of Peace
United States International Trade Commission (USITC)
United States Marshals Service
United States Military Academy
United States Mint
United States National Central Bureau (USNCB) of INTERPOL
United States Naval Academy
United States Nuclear Waste Technical Review Board
United States Parole Commission
United States Postal Inspection Service
United States Postal Service
United States Secret Service
United States Sentencing Commission
United States Supreme Court
United States Tax Court
United States Trade Representative
Upper Colorado Region
Value Engineering
Veterans Benefits Administration (VBA)
Veterans Day National Committee
Veterans Health Administration (VHA)
Veterans' Employment and Training Service
Violence Against Women Office
Vocational Rehabilitation and Counseling Service
Wage and Hour Division
Wallops Flight Facility
Washington Headquarters Services
Washington Office Fisheries
Washington, D.C. Office
Waste Isolation Pilot Plant (WIPP)
Water Management Research Laboratory (WMRL)
Water Resources Division
Waterways Experiment Station
Weapons Technology
White House Commission on Presidential Scholars
White House Office
White Sands Missile Range (WSMR)
White Sands Test Facility
William J. Clinton Presidential Library and Museum
William J. Hughes Technical Center
William R. Wiley Environmental Molecular Sciences Laboratory
Women's Bureau
World Agricultural Outlook Board
Y-12 Plant
Yucca Mountain Project Office
Yucca Mountain Site Characterization Project
( http://www.lib.lsu.edu/gov/alpha )
will have guns.
And oh, yah - "outlaws". Heh.
Cheers!
Rich
Jim Gregory
Thanks Rich
Short List helped.
Long List says it all!
