What optical mouse product works on a smooth surface?
Status
Not open for further replies.
abdan
Jan 25, 2022
11
What is the latest known tech on optical mouse, in production and market, works on a smooth granite tile surface?
Alec_t
Jul 7, 2015
3,821
Provided the smooth surface has a sufficiently fine pattern on it most optical mice should work. Such mice don't like plain surfaces though.
dave9
Mar 5, 2017
1,191
Also, it helps if the surface isn't especially shiny.
I prefer a mouse pad, easier on the hands and wrists.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
I currently use a logitech (Logi) M185 wireless optical mouse. It performs well on most smooth surfaces, except mirrors, as long as there is a textured pattern embedded in the surface. We have highly polished granite surfaces in the kitchen and in our bathrooms, but I cannot imagine wanting to use my mouse in any of those environments. Your mileage (or kilometers) may of course be different. I suggest you take a small sample of your "smooth granite tile surface" with you to a local Staples, Best Buy, or whatever brick-and-mortar store you use to purchase personal computer items, and try before buying your next mouse.
I believe most, if not all, optical mice use a small solid-state camera to image a small area under the mouse. Software performs an algorithmic computation on successive images to determine the direction and distance of mouse movement. That was some state-of-the-art shit in the previous century, but pretty common today. Of course you could try to find a mouse with a little rubber-covered steel ball, spring-mounted against two perpendicular shafts attached to two rotary optical encoders. Those worked well on just about any surface, but they did have a tendency to accumulate lint and needed periodic cleaning to restore operation. I ditched mine in the last century when an optical mouse that I could afford became available. Started with the Logitech brand and never found any reason to try another.
00sweeney
May 13, 2024
"We have highly polished granite surfaces in the kitchen and in our bathrooms, but I cannot imagine wanting to use my mouse in any of those environments."
Really?
You genuinely can't even *imagine* why anyone might want to use a mouse in their kitchen?
I think your comment says more about your imagination than it says about the question.
PS: I suspect your default reply might be something along the lines of "This question is two years old, blah blah blah" but I think a more relevant consideration would be "Wow, my answer was so bad someone felt compelled to create an account specifically so they could comment on something from two years ago."
Delta Prime
Jul 29, 2020
2,996
Because that's where I keep my cat mouse pad.
Alongside a wireless keyboard for my laptop.
And wow! your answer was so bad...
Welcome to Maker Pro! :)
Status
