What output to use from signal/function generator
Jodles
Nov 19, 2010
13
For a simple RC circuit, connected to an SG and an oscilloscope, what sinusoidal output should I use? If anyone could point me in the right direction it'd be much appreciated!
barathbushan
Sep 26, 2009
223
what do you mean by RC circuit ??
is it a capacitor charging/discharging circuit ??
barathbushan
Sep 26, 2009
223
what do you mean about chosing output ??
oscilloscopes don't chose the output but merely displays it
Jodles
Nov 19, 2010
13
It's hi-pass and lo-pass RC series circuits. We are asked what output to use from the SG (floated, earthed, 50ohm/600ohm, etc.)
barathbushan
Sep 26, 2009
223
earthed connection
regarding impedance - let me ask you a question
should the o/p impedence of a device be minimum or maximum to prevent loading ??
Jodles
Nov 19, 2010
13
It should be maximum to prevent loading, right? But in this case don't we want as much voltage across the circuit as possible? Thus a low output impedance on the SG?
barathbushan
Sep 26, 2009
223
HINT - if you use maximum resistance all the signal will drop across it , without reaching the load [in your case the RC circuit] , so think over again
