What I need for my project is some simple RF transcievers. Here is a list of the things they need to have/do:
-Crystal socket for XTAL crystals in the 27 mhz range
-4 simple pins/connections: positive, negative, data to send, data received
-Place to solder antenna to (obviously)
-Small (2x2 inches MAX)
-Range of a few hundred feet (at least 100 ft)
All of the data sent and received will be processed externally by microcontrollers. All I need the trancievers for is to "convert" electric pulses (my data) to RF and vice versa. They will serve as the wireless link between two circuits (obviously). They need to do nothing more. I simply want to hook them up to power. Then I will have a microcontroller that sends a series of pulses to the pin/connection for data to be sent, and the tranciever will send the data via RF. The same will happen for incoming data. The tranciever will pick up the RF signal and will convert it to electric pulses, and the microcontroller will read this data by connecting to the pin/connection for data received.
The quantity, frequency, etc. of pulses will be controlled entirely by external microcontrollers. The trancievers need to do nothing but send the data the microcontroller gives and receive the data it picks up via RF. They need to be that simple.
My question is, what trancievers fit this decription and cost very little (less than $10 a piece, preferrably a few bucks a piece)? Where could I get those trancievers? Thank you so much for the help.
