When was the last time you did something for the first time?
The Matchmaker
What do you want to talk about today?
Sjouke Burry
Today.
Helped a neigbour put a heavy pole in the harbour whre his boat
is parked.
I did not want to talk about it.... :)
W
Winston
Today.
Helped a neigbour put a heavy pole in the harbour whre his boat is
parked.
If I put a heavy Pole in the harbor, I would be
much quieter about it that you are. :)
--Winston
The Great Attractor
Correct. I've never taken a pole.
--Winston
In approximately 105 days, the Earth's poles will get flipped. (or show
us that it is imminent)
We all take a pole on that day.
JW
Shiny side out.
brent
I changed a timing belt and water pump on my kids car. Used the
starter to get the crank bolt off. Had to use a strap wrench to get
it back on.
amdx
The refrigerator would only dispense crushed ice not uncrushed ice.
I disassembled the panels and removed the panel holding a solenoid and
associated hardware. The roll pin that holds the solenoid plunger had
shifted and released the assembly from the plunger, so the plunger would
pull in but the assembly would not move. I inserted the plunger
and drove the roll pin back into position. I wrapped Kapton tape around
the assembly to keep the pin from sliding again. I had to do this same
repair about 8 years ago.
Oh, the first time was 8 years ago, never mind.
Mikek :)
