Where do Ifind this part...
john Gram
Oct 5, 2017
I'm repairing a Sony SRS-x55 Bluetooth portable speaker.
A piece has fallen out where the AC power adaptor fits into . I'm missing the female part. I've attached a photo of the needed part that's missing from the yellow piece.
Is it proprietary to Sony? Sony is zero help with this.
Thanks for any info.
14,317
This is rather probably a standard dc power jack. You find them in many stores, e.g. here. The important measure is the diameter of the plug.
If you don't find a matching port for PCB mounting, you can use one which is mounted into the housing, fixed by a nut, and use wires to connect with the PCB. In that case, observe polarity!
john Gram
Oct 5, 2017
Thanks for the info Harald. I'm curious to try the nut idea for learning purposes.
