White noise generator
John Larkin
Noise across the audio spectrum of a small speaker. The speaker will be
some metres away from the signal generating part of the device. The noise
level must be controllable nearly upto the limit of the speaker.
I have just about come around to the idea of a 12 volt Zener diode driving
two LM741s followed by a LM368N to drive the speaker. The op-amps would
have a 12 volt unbalanced supply with the + inputs of the LM741s biassed to
6 volts. The parts are all available and cheap. I have the speaker. Would
this work in your view?
You can't really zener a 12-volt zener from a 12-volt supply.
And 741's are notoriously noisy themselves, which can cut both ways.
John
Roger Dewhurst
John
Thanks. Should I use a lower voltage zener diode then? The extra noise
will not matter.
Roger
John Larkin
will not matter.
Roger
If you use a 6-ish volt zener, it can be the supply splitter, too!
John
Roger Dewhurst
John
Connect the + input directly to ground and feed the signal through a (?)100
nF capacitor and a resistor into the - input?
Roger
John Larkin
Roger
See my sketch in a.b.s.e.
John
Jasen Betts
Thanks. Would a 741op-amp drive a small speaker?
if your small speaker has an impedance of 50 or more ohms and ypu
don't need it very loud it could work.
an LM386 is a better choice for a small 4 or 8 ohm speaker.
Bye.
Jasen
James Beck
I would be grateful for suggestions on constructing a simple random noise
generator. Most of the noise should be within the audio spectrum.
Record one of Howard Deans' speeches/rants.
That's some pretty good white noise.
Roger Dewhurst
My ISP does not provide a.b.s.e which I presume is a binary ng covering
electronics. I would be very grateful if you could manage to email me the
drawing as a .jpg file.
Roger
Roger Dewhurst
That fellow, whoever he may be, is of so little interest to anyone in this
country (NZ) that his rants are unavailable and unrecorded.
Jasen Betts
electronics.
it is. "alt.binaries.schematics.electronics". (note to self:"Avoid IHUG")
fwiw Clear and compass/freenet carry it. compass/freenet's server
is half-arsed. AFAIK there's me and maybe two other people who actually
use it.
