Jim Thompson wrote:
On Oct 14, 10:16 am, Phil Hobbs
[email protected] wrote:
On Oct 14, 5:48 am,
Folks,
The subject line almost says it all. What I mean with small is a nice
flat inductor like this:
[snip]
For the young folks: A swinging inductor is one where the inductance is
really high at very low currents and then drops off significantly
towards the full rated current, due to partial core saturation.
"Partial" is the trick. So it has nothing to do with swingers
Not a commodity, because there's no concensus on what the slope should
look like. You can wind toroid sets on an smd platform (40705TC +
00M0804T200 gives a .310 OD x .25H 'compound' core). Alternately, you
can order irregularly ground gaps.
What are you using, so far, to prove that this is a cure to all of
your light-load problems? (See what I mean?)
How about paralleling two stock SMD inductors with different
saturation points?
(Joerg might wince at two parts and double real-estate, though.)
Um, on 2nd thought, series-connection's more reasonable, values-wise,
but the series resistance might be a nuisance.
Cheers,
James Arthur
Especially since they'd both have to be swinging chokes for it to work.
Joerg's idea of stacking high- and low-mu cores and running the winding
through both of them sounds like the ticket.
Cheers
Phil Hobbs
No, they don't have to both be swinging choke.
Here--put two in series, L1, a high-valued low-esr choke that
saturates easily, and L2, low-valued and high-saturation current.
_________| | | |_____| | |____
L1 L2
At low currents, the inductance is L1+L2.
Once L1 saturates, it's a resistor (low-valued, by design), and L2
takes over.
Yep. I now have my Spice model refined for a smoothly converging
saturating inductor, if anyone is interested.
<raising_hand>
Only if useful in LTSpice though. I have used saturable cores in LTSpice
but haven't used too elaborate a function. And I'll have to dig in
really old stuff to find it
The main issue with two inductors in series is that the mfg for L1 won't
release saturation data, at least not in writing. Because you aren't
s'posed to do that. But I hafta. You can measure it on the impedance
analyzer and use the found data in the design and everything is peachy.
Then one sunny day Murphy strikes, the day the mfg changes ferrite
vendors ...
When you specify the data for the custom part, just include the needed
parameters for non-saturated currents and for saturated currents, that
fits your bill. If the go outside this tolerance band, the part is
discarded. That forces the supplier to deliver the same parts that you
did the initial testing on
Regards
Klaus
