GeekBoy said:
This week's Home Depot circular has an a solar powered attic fan for $168.
Comes with 10 watt solar panel and available for either gable (item
#607688) or roof mount (item # 607690).
When I do the math, a 10 watt panel will provide enough energy to do
precious little air movement. I would probably go with a whirlybird vent,
backed up by a small duct-mounted AC fan, controlled by a two-stage
thermostat. The first stage would open an electric damper in the duct,
allowing the whirlybird fan to suck out the air. Then if the whirlybird fan
on the roof isn't doing enough, or if there's no wind, the fan in the duct
would kick in at the second stage of the thermostat. This way, you would get
adequate and controlled airflow at minimal cost, utilizing the wind whenever
possible.
Solar energy is free, but expensive, and rarely worth the investment when
grid power is available. Wind power is both cheap and free, but it's the
least reliable source. I think the best choice is wind-driven ventilation
with a grid power backup.
