Why caps in paralell?
walid1
Jun 27, 2004
749
the caps at the right, why 10p//15p? what if use one 25p cap?
thanks
audioguru2
Apr 6, 2004
12,022
25pf is not a standard value. 10pF, 15pf, 22pF and 27pF are standard values.
Hero999
Oct 28, 2007
2,433
Not that it matters, 22pf or 27pf could be used instead.
Another reason for using many capacitors in parallel is it gives lower impedance to higher frequencies if they're spread across the PCB traces.
walid1
Jun 27, 2004
749
I understand from your words that if I had two caps, one of them is equal to 5p and the second = 10p.
Better to use the two in parallel to get 15p and not one 15p to make an easy path for the high-frequencies toward ground???
