Vladimir Vassilevsky said:
Adrian said:
Several of my own P.A. designs (all transistor) have soft clipping in
the driver stages. On the occasions where I have had to run them
overloaded[1], they sounded much louder than their numerical wattage
would have suggested and there were no complaints about distortion.
A typical audiofool ignorance.
I am just as scathing of audiophoolery as you are; this comment was
based on 40 years of practical P.A. experience as a designer and as an
operator.
The amount of nonlinear distortion = deviation of the transfer curve
from the straight line. Soft clipping = more distortion if compared to
hard clipping to the same ceiling.
Soft clipping gives less audible distortion on a low fidelity P.A.
loudspeaker system. If an amplifier has to wound up to too high a level
in order to deal with an awkward situation 'in the field', it is
infinitely preferable to hear soft clipping in the top 6dB of the signal
than to endure the harsh distortion from flat-topping.
If the amp has to enter the area where it clips the signal, one has to
limit the windup of the integrators in the feedback path. So the
recovery from the saturation will be quick.
With soft pre-clipping, the power stages are less likely to saturate at
all.
There are other reasons for using as little feedback as you can get away
with on a P.A. amplifier:
Most designs need an output transformer to feed the floating 100v line,
so a tertiary winding, close coupled to the secondary, is the only way
to give meaningful feedback. There may be considerable phase shifts due
to resonance between the the self-capacitance and inductance of the 100
volt winding.
The load is unpredictable and the amplifier must remain stable under all
sorts of conditions from an open overhead line several hundred yards
long (during set-up) to a short circuit (when some idiot drives a nail
through the cable). If there is significant leakage inductance between
primary and secondary, it won't take much feedback from the secondary to
give instability under some conditions of loading.
My comments about soft clipping applied to difficult underpowered P.A.
situations where turning the volume down isn't an option and you are
forced to choose the least of several evils. I am not advocating soft
clipping for high quality sound reproduction (where adequate amplifier
power is the obvious first step).
